Briggs & Stratton Flywheel Timing
this thread has 4 replies and has been viewed 511 times
Old 06-12-2019, 12:20:44 PM
foxtail foxtail is offline
Default Briggs & Stratton Flywheel Timing
I tightened a b&s flywheel with an impact tool. Now it’s out of time. What did I screw up? The key is still good. Someone told me the magnets inside the flywheel is causing it, but they look like they haven’t moved. It fires about 1/4 turn too soon. Is there any good news out there? Thank you.
Old 06-12-2019, 12:52:18 PM
radiodoc radiodoc is offline
Default Re: Flywheel
A model, type and serial number would help out here. Double check the key. If the engine has points, make sure they are gapped correctly. Guessing twenty thousandths. Others will chime in when they have time.
Old 06-12-2019, 01:12:27 PM
Is it the correct wheel for the engine? Although it fits, there are differences and since your timing is way off perhaps it may be the case.
Old 06-13-2019, 02:28:28 AM
cobbadog cobbadog is offline
Sounds as if the wrong flywheel is on the engine. So check the position of the magnets when at TDC.
I do have to ask why did you use an impact wrench to tighten it?
Make and model is a help too as suggested.
Old 06-13-2019, 11:07:23 AM
Default Re: Briggs & Stratton Flywheel Timing
B&S points set .020". Tightening a flywheel with an impact wrench is a NO-NO! Doing so will cause the crank to swage the taper, possibly splitting the flywheel hub and offsetting the position of the magnets (flywheel warp).
Correct flywheel for the engine? Correct magneto? B&S changed flywheels and mags over the years. At TDC Compression, the second magnet should be just under the following leg of the magneto. For the electronically controlled mags, magnet timing is critical. Check your keyway too. B&S made offset keys for some engines, and if installed wrong, will make timing off.
Briggs & Stratton FH Flywheel 60Chevyc10 Small Air Cooled Gasoline Engines 5 03-08-2019 01:52:15 PM
Briggs & Stratton 23 Timing Nick Lingg Small Air Cooled Gasoline Engines 2 06-15-2014 02:03:24 PM
Timing a Briggs & Stratton mag. shakeyjake36 Small Air Cooled Gasoline Engines 9 03-30-2013 07:00:33 AM
Briggs and Stratton 8R6 Timing MasseyMan1089 Small Air Cooled Gasoline Engines 2 01-15-2012 03:01:55 PM
Briggs & Stratton Cam Timing Frank Martin Small Air Cooled Gasoline Engines 6 05-31-2006 11:12:33 PM
