Welding Shop
Hobart Welder Parts
this thread has 9 replies and has been viewed 23978 times
Old 09-20-2004, 12:36:33 PM
John Bailey
Default Hobart Welder Parts
I have an old Hobart Welder, probably 1940's vintage. Unfortunately I do not know the model number. It is a 300 amp DC welder and is powered by a Wisconsin V4 engine. One of the brushes on the exciter generator is broken. Does anybody know of a parts supplier for old Hobart welders?
Old 09-21-2004, 01:41:55 AM
Franz
Default Re: Hobart welder parts.
When ITW bought Hobart Bros, they were forced to break the company up, and most of the heavy equipment line was sold to Thermal Dynamics. TD definitely ain't a helpful company. You might have luck posting a picture of the unit on http://www.hobartwelders.com/mboard/ and if you get really lucky, one of the factory people might help you.
Old 12-14-2005, 10:31:25 PM
bigal
If you have A company that rewinds elec. motors or works on elec. motors they can match them up. Thats where I had to get A set. Big Al
Old 04-19-2010, 09:02:17 PM
sparksweldingandfab sparksweldingandfab is offline
weldmart carries the brushes that will work on that hobart just take the measurements and tell them what you need, I believe the sa 200 brushes are the same.
Old 04-19-2010, 09:04:35 PM
oops didn't look at the date on that post lol.
Old 06-16-2010, 02:07:36 PM
greg black greg black is offline
Hello,
I have a Hobart W-250 welder and I can not find new brushes, can you help with this?
Greg
Old 06-18-2010, 05:50:54 PM
Dempster Dempster is offline
Miller bought out Hobart and discontinued lots of things for older ones but they do have a site for parts & manuals you can try that or try Bill's in OKC or Stumpf's in IL or Hybriweld / Fowlers in LA all are welder service shops. Also including links to some brush companies.
http://www.billswelderrepair.com/home.html
http://www.stumpfweldingsupplies.com/
http://www.hybriweld.com/
http://www.helwigcarbon.com/products/index.aspx
http://www.repcoinc.com/
http://www.acecarbon.com/
http://www.carbonbrush.com/
Old 06-25-2016, 06:25:36 PM
JamesAConant JamesAConant is offline
Go to www.carbonbrush.com, they are a divison of Arrowhead electric. Punch in Hobart brushes and you will get a listing of the brush you need. You will have to have a sample of the brush so that you can get the size correct. Also look on the side of the brush, there will be a number stamped into it and you can go on line and find them.
Old 09-13-2016, 09:17:45 PM
allneon allneon is offline
Default Re: Hobart Welder Parts
i may b buying a hobart tmorrow if it has a 4cyl wisconsin on it. i need the motor, dont need the welder, if it is a 300 amp, i will get in contactwith you. thanks!
Old 09-21-2016, 07:20:51 PM
just picked up a 250 amp hobart, powered by a willeys 4cyl flat head. looks complete dont know if any parts will work for you, see pix below
ID:	263500   Click image for larger version
ID:	263501   Click image for larger version
ID:	263502   Click image for larger version
What do you know about this Hobart TIG welder ? cub102 Welding Shop 10 11-27-2013 08:34:57 PM
Old hobart welder cub102 Welding Shop 7 01-30-2012 05:44:54 PM
Hobart GR-303 Welder-Gen Help Jim Tremble Generators & Electric Motors General Discussion 7 01-27-2011 11:42:49 AM
Hobart/Ford v8-60 welder parts John Hamilton Welding Shop 1 03-20-2008 02:07:16 PM
old hobart welder Dan Potter Welding Shop 1 06-16-2007 01:54:52 PM
