Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Johnson 5.5 Seahorse Recoil Help
this thread has 4 replies and has been viewed 415 times
Old 07-04-2019, 08:05:05 AM
Dustin D Ehli Dustin D Ehli is offline
Default Johnson 5.5 Seahorse Recoil Help
Going to replace spring in the recoil housing of a 50s 5.5 seahorse.
When I reassemble what is supposed to create the friction to make the pawls engage, the center bushing bolts to the housing and stays put, the only way I could see is from friction with the center bushing and the tin plate that holds the springs for the pawls, but it just spins and they won't go out unless you hold with your finger tip.
There is a big spring under the tin plate but there isn't near enough pressure from that to make enough friction to hold the tin plate which would then make the pawls engage.
I will throw this whole thing in the garbage if I can't figure this out soon.
Having a blast preserving the past.
My Youtube Channel
Old 07-04-2019, 08:09:06 AM
Default Re: Johnson 5.5 seahorse recoil help
Here are some pics, there is nothing that catches on that tin plate all i can see is that it's supposed to be friction that holds it back and makes it pull the springs to engage the pawls, if I do that with my finger tip it works perfectly but there isn't enough when just bolted together.
It did work when I took it apart to replace the recoil spring, so this is really pissing me off.
Thanks guys
ID:	338502   Click image for larger version
ID:	338503   Click image for larger version
ID:	338504   Click image for larger version
My Youtube Channel
Old 07-04-2019, 09:15:21 AM
Does anyone have a service manual that shows or explains how this recoil is supposed to work or go together.
I know I have it put together correctly but can't see how it gets enough friction to hold back the tin plate to engage the pawls
My Youtube Channel
Old 07-05-2019, 01:49:46 PM
Angry Re: Johnson 5.5 Seahorse Recoil Help
Got it all reassembled with new stuff, tweaked the plate to create friction, worked for about 10 pulls and now it just freewheels again, wont engage pawls.
Damn thing
My Youtube Channel
Old 07-20-2019, 09:52:59 AM
Default Re: Johnson 5.5 Seahorse Recoil Help
it needs more friction washer/shim.
Johnson Seahorse TN26 Zen Antique Marine Engines and Outboard Motors 8 01-05-2015 02:46:56 PM
Johnson Seahorse Model TDL-20 Robert Jackson Antique Marine Engines and Outboard Motors 10 08-21-2013 12:32:50 AM
1940's era Johnson Seahorse questions dieselfitter Antique Marine Engines and Outboard Motors 6 01-02-2011 06:44:19 PM
Johnson Seahorse magneto susprise ehpower2 Magnetos, Ignition Coils and Spark Plugs 16 03-14-2010 03:39:57 PM
Johnson Seahorse TD 20 ehpower2 Antique Marine Engines and Outboard Motors 1 04-11-2009 12:31:41 AM
