Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Eclipse inboard help needed
this thread has 1 replies and has been viewed 203 times
Old 08-20-2019, 12:58:16 AM
Mark20h Mark20h is offline
Default Eclipse inboard help needed
I have a single cylinder Eclipse inboard with a loose rod. Has anyone had one apart? I need to find out if it has a bronze rod or Babbitt or insert rod bearings. Thanks
Old 08-20-2019, 03:46:06 PM
Default Re: Eclipse inboard help needed
Does not matter what they are made of, unless severely worn, just open up and remove a shim or two and re-check clearance. If it has a bronze rod and no shims, you can use some 150 grit sand paper and re-fit the clearance. In any case, you still have to get inside to see the problem. While you are in there, take the time to check the wrist pin clearance and wear too. It will save you time going back in to stop top end knock that you cannot now hear, due to the noise on the bottom end! Been there, done that!
Fairbanks Morse Eclipse - help needed crazydoug Hit & Miss Gas Engine Discussion 5 10-22-2018 08:52:49 PM
Eclipse Inboard Motor Mark20h Antique Marine Engines and Outboard Motors 2 09-10-2018 09:50:38 PM
Eclipse Inboard Mark20h Antique Marine Engines and Outboard Motors 1 08-25-2018 09:47:50 AM
Evinrude Inboard – General help & advice needed. AusAnzani Antique Marine Engines and Outboard Motors 2 07-03-2016 09:35:44 PM
Eclipse help needed caf Hit & Miss Gas Engine Discussion 10 02-25-2008 03:42:52 PM
