Welding Shop
Welding Steel to Cast Iron
this thread has 20 replies and has been viewed 57184 times
Old 04-11-2013, 09:42:49 PM
TractionEngines TractionEngines is offline
Default Re: Welding Steel to Cast Iron
If you want to MIG it Esab Nicore55 is a good wire made specifically for this type of thing. Two issues tho wire is pricy and the shield gas has to be 98% argon 2% oxygen.
also dont try on 120v welder (inverter type). needs a big mig with the transformer and choke. 200A+. short welds pulses. and it works great for welding cast and joining dissimilar metals.
Just my choice for this type of work.
Welding cast iron and steel together. Jim Rankin Blacksmithing and Metallurgy 13 05-14-2015 07:47:53 PM
Cast iron welding Kelly Tytlandsvik Welding Shop 3 02-01-2012 10:24:13 PM
Cast Iron Welding crazycajunred Welding Shop 3 05-16-2011 06:53:51 PM
Welding cast iron off old engines (WITH STAINLESS STEEL RODS) P Grogan Hit & Miss Gas Engine Discussion 36 01-31-2010 04:21:14 AM
To make new valves - cast steel / cast iron Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 05-02-2009 12:53:18 AM
