Briggs and Stratton 8R6 Timing
this thread has 2 replies and has been viewed 2079 times
Old 01-14-2012, 07:40:50 PM
MasseyMan1089 MasseyMan1089 is offline
Default Briggs and Stratton 8R6 Timing
I have an 8R6 engine, with the 6:1 reducer from the factory. I put a set of rings in it and at the time of disassembly, I didn't realize that I could not see the timing marks! I can see the dash on the cam gear, but not on the gear on the crankshaft. Any suggestions on how to properly time it??
Old 01-15-2012, 12:07:22 AM
Tom Schaech Tom Schaech is offline
Default Re: Briggs 8R6 Timing
Look closely at the crankshaft gear. There should be some sort of a mark on one of the teeth. Sometimes a slight bevel was put on a tooth by the factory. If memory serves me correctly, the timing mark on the cam gear would be at the base of two teeth; usually a dot stamped into the gear face.
Hope this helps...
Tom
Old 01-15-2012, 03:01:55 PM
There were no marks to be found on the teeth. I did find a dash on the crankshaft itself, which I lined up with the timing mark on the cam gear. I put it together like that and it seems to be right when I spin the motor over. So we will see!
Briggs and Stratton 5hp lihelp Small Air Cooled Gasoline Engines 6 01-28-2012 08:07:54 PM
Briggs & Stratton WMB brian leonew Small Air Cooled Gasoline Engines 9 05-12-2009 10:03:36 AM
11hp briggs & stratton timing peggyfran1 Garden Tractors and Mowers 8 09-18-2008 11:02:54 PM
Briggs & Stratton Cam Timing Frank Martin Small Air Cooled Gasoline Engines 6 05-31-2006 11:12:33 PM
Looking for Briggs & Stratton Timing Gauge (MPJ) Jonathan Widelo Small Air Cooled Gasoline Engines 0 02-23-2005 02:34:18 PM
