Gilson timing questions...
this thread has 12 replies and has been viewed 2486 times
Old 03-30-2012, 02:56:47 PM
Edwin
Default Gilson timing questions...
Hello i took my gilson apart and gave it some new paint,and i would like to know if my engine is timed correctly,it ran pretty slow last week just before i took it apart.Of course it wont run now,could someone tell me how to over look the timing and exhaust ,see i have it right with this engine.This would be alot of help to me.I have a soft spring on the gov to get it to run slow,and im trying to start in cooler weather,and have it oiled with 50 wt. oil.Will this make a difference?
thanks
The Following 2 Users Say Thank You to For This Post:
Old 03-30-2012, 02:59:47 PM
Ron Haskell's Avatar
Ron Haskell Ron Haskell is offline
Default Re: Gilson timing questions....
The generic timing for flywheel engines is: exhaust valve should start
to open 35-45° before bottom dead center, and close 5° after top dead
center. Spark should occur 5-7° before top dead center for each 100
revolutions per minute. With the greater number being used for low
tension ignition and the smaller used for high tension ignition
Old 03-30-2012, 05:19:06 PM
Edwin
Photo Re: Gilson timing questions....
Hello what im after is a close up pic of someones Johnny on the spot Gilson.I need a pic showing the crank and timing gear up close and some idea where it should be timed. I have a feeling the gear was mis-meshed before i had a chance to stamp it in order to know what teeth need to mesh where.Please if you have a gilson like this could someone post a close up picture of the gear, piston and cam in the same pic.I need a rough idea in order to know if mine is out of time.Here are a few more pic of the engine im having a hard time with.I feel bad in asking as i have had this engine running very well in the past.
thanks
ID:	132134   Click image for larger version
Old 03-30-2012, 05:37:54 PM
Edwin
just wondering if the piston is in the right spot? the exhaust valve cam is pointing straight upwards.
Old 03-31-2012, 05:18:45 PM
E.C. Mims E.C. Mims is offline
Usually, a good starting point is to have the cam and the crank point straight up.
Old 04-01-2012, 11:58:18 PM
Edwin
So your saying the crank shaft and exhaust cam should both be pointing straight up?I really could use a good picture showing a gilson johnny close up ,so i can see how it should look.I have looked at the gilson index from a fellow stacker,Denis R, i hope someone can help me out with this mess,would really like to hear this engine run again.
Old 04-04-2012, 04:14:29 PM
Email NOT Working
Edwin,
I think you can get it without a picture. Just rotate the flywheels slowly backwards (like you're starting it) and make sure the exhaust starts to open up before bottom dead center. Then make sure the exhaust is likewise closing just before top dead center so your intake can open on the intake stroke.
Of course the pushrod or rocker arm adjustment will have something to do with it, but if you can't get it right, just move the cam one tooth ahead or back.
Then roll the engine through again, thinking to yourself, "Intake, compression, power, and exhaust" as the piston goes up and down.
Kevin
---------- Post added at 03:14 PM ---------- Previous post was at 03:12 PM ----------
To clarify, exhaust starting to open bottom dead center on the POWER stroke.
staying open until just before top dead center on the exhaust stroke.
Kevin
The Following User Says Thank You to Kevin O. Pulver For This Post:
Old 04-04-2012, 05:06:24 PM
Edwin
The engine she runs again!! thanks everybody i didnt have to do a thing to it other than add enough gas and add a bit more tension to the springs.Some time you just over look the small stuff
Old 04-04-2012, 07:28:00 PM
any video of it running Edwin?.great to see it is coming along.John
Old 04-05-2012, 08:16:05 AM
Edwin
http://www.youtube.com/watch?v=6B742...eature=channel
---------- Post added at 08:16 AM ---------- Previous post was at 08:11 AM ----------
Its coasts for about 11 revs,then fires.Thats as slow as i can get it to run and stay running have had it running slower just didnt stay running that long.Pretty good i think for a short stroke gilson.
Old 04-05-2012, 09:58:05 AM
Will Batty's Avatar
Will Batty Will Batty is online now
Good Job Edwin!
Looks and runs good! My Gilson also likes to run a lil faster. Like you said with the short stroke they like to run quicker. My engine has excellent compression as well so it is not a real good super slow running engine.
Name:	Old Pictures 670.jpg
The Following User Says Thank You to Will Batty For This Post:
Old 04-05-2012, 12:10:05 PM
Edwin
Will,think i heard your engine run ,is it on youtube?If so you have a sweet running engine.I find the carb on gilson engines doesnt have enough settings for fine tunning a slow running engine you only have a few settings,on that style carb.Full choke closed all the way, partial choke ,half choke and full open no choke.
Old 04-05-2012, 03:56:16 PM
runs great Ed. i had not seen the video of it before you restored it. still runs great.John
A couple of IHC LA questions. Timing bergrider01 Hit & Miss Gas Engine Discussion 2 01-19-2011 03:26:32 PM
Stover/Economy CT1 Timing Questions Zira Hit & Miss Gas Engine Discussion 2 09-07-2010 07:33:48 PM
Montgomery ward/ Gilson and Onan questions Ken Karrow Garden Tractors and Mowers 1 08-01-2010 09:50:34 AM
Gilson questions R. Kern Hit & Miss Gas Engine Discussion 4 01-18-2009 10:46:51 PM
JB Series Timing Questions??? Cat Man Onan Generators 4 01-07-2009 05:27:57 PM
