Welding Shop
1963 Lincoln Red Face SA 200 resto project
this thread has 34 replies and has been viewed 17645 times
Old 10-23-2012, 09:51:17 AM
Kpack
Default Re: 1963 Lincoln Red Face SA 200 resto project
Stay with it Jim you got it looking real good.
Old 11-05-2012, 11:14:13 AM
Jim Sherman's Avatar
Photo Re: 1963 Lincoln Red Face SA 200 resto project
Impatiantly waiting for my new water pump to arrive!!! That's the last part, then fire up!
ID:	148732   Click image for larger version
ID:	148733   Click image for larger version
ID:	148734   Click image for larger version
Jim Sherman
My website
Old 11-05-2012, 12:08:01 PM
Kpack
Looks good Jim I'm ready to see it go and i know you are . Looks like you got some more stuff around there to play.
Old 11-12-2012, 10:54:19 AM
well it runs like champ but the R57 idler solenoid is toast. Looks like I am going to have to install a new electronic idler. Darn it. The old R57's have been made obsolete and new solenoids are no longer available.
On the plus side I was able to manually rev it up and weld with it, and it purrs like a kitten!
Jim Sherman
My website
The Following User Says Thank You to Jim Sherman For This Post:
  #25
Old 11-12-2012, 02:05:39 PM
Kpack
Congratulations I know you we're ready to hear it run
Old 11-14-2012, 12:50:45 AM
motormanjeff motormanjeff is offline
I saw one of those R-57 idlers on ebay(nos) not to long ago. It would be nice to keep it original. You could check with some of the welder repair shops. Most of us pipe welders switch to the electric idlers because the grinder also revs these up, where as the r-57 needs pinned open for the grinder. On one of mine I rigged up a switch with a solenoid on the vaccume to rev it up. They may have a used one that could be cleaned up to get working. Did you check the idler? Sometimes they just need cleaned and adjusted with a new ciggarette filter. Good luck, Jeff.
The Following User Says Thank You to motormanjeff For This Post:
  #27
Old 11-14-2012, 10:41:00 AM
Thanks Jeff. You are 100% correct! Someone way long ago completely removed that little felt filter. My dad had told me there was something wrong with the idler when he bought the welder over 40 years ago. He rarely used it and when he did he just pinned the linkage. I took the R57 over to a local shop and the guys there put a cig filter in it and a small copper shim inside the solenoid. We adjusted it there and tested it and it works perfect. I'll put it on this weekend and adjust the governor. I am pretty sure everything is out of whack. I'll "shelf" the new electronic idler I ordered from Hybriweld, for now. I really won't need a grinder on it so not revving up the 110v with the old school idler is okay with me. It's just a home shop machine right now.
Jim Sherman
My website
Old 11-15-2012, 05:51:52 PM
Updated video:
Jim Sherman
My website
Old 11-19-2012, 11:34:47 AM
Finally the time came this weekend to get everything "dialed in" I had stated earlier that the R57 idler was working correctly.... well, it did on the bench but did not once on the machine I was able to strike an arc while looking at the plunger on the solenoid, I lifted the boot and noticed that the needle was not dropping as it should I pulled the R57 back off, stretched the needle spring a little and that did the trick. Runs, welds, idles low and high as it should, and generates power. I am very happy with this SA200!
ID:	149905   Click image for larger version
ID:	149906   Click image for larger version
ID:	149907   Click image for larger version
Jim Sherman
My website
Old 11-19-2012, 12:17:57 PM
Axtion Jim S Axtion Jim S is offline
Now you have a real welder, worth about ten grand in Edmonton.
The Following User Says Thank You to Axtion Jim S For This Post:
  #31
Old 11-19-2012, 12:30:22 PM
they sure do get crazy money for these 1960's Red Face's. It may not look the prettiest but other than a paint job it's in fantastic condition now. I like the "working clothes" it's in, no fancy paint job will make it weld any better so this is it.
Actually there is one last thing I plan on doing and that is having the generator baked and painted internally. Then she's done. Hopefully good for a few more decades.
Jim Sherman
My website
Old 11-19-2012, 01:50:26 PM
Kpack
proud for you jim i have watched the whole way
  #33
Old 11-19-2012, 02:05:20 PM
This one has been pretty close to my heart. My dad bought it from a company that he worked for, his ex father inlaw at the time (my grandpa) was part owner of that company when the machine was bought new, my dad went on to own a part of the company, and now I am a shareholder in the company. I was just a young boy back when my dad bought it and I learned how to weld with it. Now it's mine, and my son has been able to help get it back into shape, learn a few things along the way, and he'll learn how to weld with it.
Name:	Emmett wiring.jpg
Jim Sherman
My website
  #34
Old 11-25-2012, 12:15:04 PM
Erik Wolf Erik Wolf is offline
i am working on a Lincoln SA-200 i was looking up the R57 idler and i find this website and i find a old friend working the same welder. i welded my old 1948 Willy's jeep
---------- Post added at 11:15 AM ---------- Previous post was at 11:13 AM ----------
i am working on a Lincoln SA-200 i was looking up the R57 idler and i find this website and i find a old friend working the same welder. i welded my old 1948 Willy's jeep with your welder.
The Following User Says Thank You to Erik Wolf For This Post:
  #35
Old 11-25-2012, 05:16:18 PM
Stay with it Erik they're fine machines as you know. Try weldingweb.com and aws.org for more on the SA200's!
Jim Sherman
My website
Unusual Myrick model B resto album PaulGray Oil Field Engines & Related Equipment 1 01-01-2010 08:42:03 PM
Wachs vertical resto Rick Strobel Steam Stationary Engines, Traction Engines 1 07-05-2005 06:12:05 PM
Nice Resto on this cast iron radiator Rick Strobel Hit & Miss Gas Engine Discussion 4 06-18-2005 01:13:15 AM
Tap Magic ProTap and resto work Paul Gray Antique Engine Archives 1 12-29-2003 12:14:27 AM
anyone got videotapes of an engines resto? Jay Bernard Antique Engine Archives 0 08-04-2000 11:20:17 PM
