Welding Shop
Brazing cast iron
this thread has 23 replies and has been viewed 63529 times
Old 11-07-2008, 01:08:53 PM
terry tabb
Default Re: Brazing cast iron
i didnt read all that ,if you look at the post i just put on , use them old oak pallets, the fin on top of the maytag was broke off, i made a piece of iron to match the other side, got the high grade nickel rod at the welding shop , groved the joint, weld a 1/4 to 1/2 " got my grinder gound it back flush, weld again , same way over and over til you have the crack or seam done , strike the rod to flash over the top of the welded area to give it the cast look , you might need to do that a few time to get the look , then you dont have a big blob that look like its fixed , well i hope this helps , if you dont think it is stong i did the same thing to a piston rod , yea i still wonder about that but it still running , i left the blob look on it ,
Old 03-07-2009, 07:15:55 PM
Langes Machine Shop Langes Machine Shop is offline
You are using the wrong rod and fux bring it to people who do it for a living. We stand behind every piece of cast the we have welded with bronze. Jason
Old 12-28-2012, 02:10:05 PM
Email NOT Working
Their videos on #1 and #5 rod for oxy-acetylene or Propane torch repair of aluminum and yes, POT METAL is amazing.
I've wanted to order some for a long time, and finally did today.
Old 12-29-2012, 02:14:46 PM
S Davey S Davey is offline
What about Silver Solder?
White Stay-Silv flux any use in brazing cast iron? sdowney717 Welding Shop 6 12-29-2015 06:22:55 PM
Recommendations for a torch for brazing / welding cast iron beezerbill Welding Shop 9 08-28-2013 09:34:04 AM
Broken Sub Base: Mold, Cast, Cast Iron Weld DaveTexas Hit & Miss Gas Engine Discussion 24 03-17-2011 12:00:46 AM
Cast Iron Brazing Company in CA. Greg Johnson Hit & Miss Gas Engine Discussion 2 07-02-2009 12:00:32 PM
To make new valves - cast steel / cast iron Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 05-02-2009 12:53:18 AM
