Oil Field Engines
Myrick Eclipse burner tube length
this thread has 1 replies and has been viewed 1265 times
Old 03-28-2013, 08:18:29 AM
Jonah Close's Avatar
Jonah Close Jonah Close is offline
Default Myrick Eclipse burner tube length
How long should the burner tube be on a 4 hp Eclipse? Thanks
Old 03-28-2013, 09:50:06 AM
Default Re: Myrick Eclipse burner tube length
The hot tube on my engine is 6", the pipe length on the burner is about 3".
The Following 2 Users Say Thank You to Bill Hazzard For This Post:
Myrick Eclipse 4 HP Air Cooled Hot Tube Hit & Miss Manual Needed Tom Gosciminski Hit & Miss Gas Engine Discussion 14 12-15-2015 09:46:10 PM
Myrick eclipse hot tube chimney part number? Jonah Close Oil Field Engines & Related Equipment 1 12-25-2012 07:08:17 PM
Fairbanks Morse Hot Tube Burner help Michaely Smokstak Down Under 5 02-28-2011 08:29:28 PM
Hot tube burner help needed Greg Johnson Oil Field Engines & Related Equipment 4 09-15-2010 05:25:21 PM
hot tube burner larry harding Antique Engine Archives 0 01-31-2001 10:55:21 PM
