Briggs & Stratton 23 Timing
this thread has 2 replies and has been viewed 916 times
Old 06-15-2014, 11:02:16 AM
Nick Lingg Nick Lingg is offline
Default Briggs & Stratton 23 Timing
Hi: Is there a trick to setting the timing on a Briggs 23? I have the manual and have checked and rechecked what it tells me to do. Then I walked away and came back and checked and rechecked everything again. I have not removed the cam and the engine did not have an ignition box so I got one from another engine. Help I need a direction to look.
Old 06-15-2014, 12:17:37 PM
Partsman Partsman is offline
Card Sponsor
Default Re: Briggs & Stratton 23 Timing
Hi Nick Did the replacement ignition box come from a 23? If not that's your problem. The boxes look the same but the arms are different lengths where they contact the cam. Jim
Old 06-15-2014, 02:03:24 PM
That's it Jim the one I have is dim. "A" 1.1" it should be about 1/4" longer
Briggs and stratton crank timing chucksue Small Air Cooled Gasoline Engines 16 10-23-2013 01:05:53 PM
Timing a Briggs & Stratton mag. shakeyjake36 Small Air Cooled Gasoline Engines 9 03-30-2013 07:00:33 AM
Briggs and Stratton 8R6 Timing MasseyMan1089 Small Air Cooled Gasoline Engines 2 01-15-2012 03:01:55 PM
Briggs & Stratton Cam Timing Frank Martin Small Air Cooled Gasoline Engines 6 05-31-2006 11:12:33 PM
Looking for Briggs & Stratton Timing Gauge (MPJ) Jonathan Widelo Small Air Cooled Gasoline Engines 0 02-23-2005 02:34:18 PM
