Go Back   SmokStak > SmokStak® General Discussion > Live Auctions of Engines, Tractors and Old Iron
Live Auctions of Engines, Tractors and Old Iron Live auctions and estate sales of engines, tractors, and old iron machinery. Upcoming auctions and auction results.
Cletrac Crawler
this thread has 14 replies and has been viewed 4825 times
Old 12-02-2014, 11:25:31 AM
pauljac pauljac is offline
Default Cletrac Crawler
There is a Cletrac crawler with radiused rear fenders coming to auction on 12/6. Go to http://www.auctionzip.com/cgi-bin/au...062&category=0 and type in zip code 14062. It is at the Forestville, NY auction.
Old 12-03-2014, 09:46:09 AM
Emmo213 Emmo213 is offline
Default Re: Cletrac crawler
Looks like you'll have to pull it out of the weeds.
It's probably easier to just post the link to the sale: http://www.auctionzip.com/cgi-bin/au...062&category=0
Old 12-04-2014, 09:51:14 AM
Default Re: Cletrac Crawler
Thanks, with the radiused rear fenders it appears to be a model 30A. Is this correct?
Old 12-04-2014, 06:31:21 PM
19-65Port 19-65Port is offline
Its not a 30A, not even close.
Old 12-04-2014, 09:16:34 PM
Junkologist's Avatar
It's a Cletrac HG. Hard to tell from the pics, but it might be a narrow gauge tractor.
Mike
SmokStak member #146
Old 12-05-2014, 01:48:34 PM
bigGURN's Avatar
bigGURN bigGURN is offline
Yep, an HG and more than likely a narrow gauge, given that the fenders are tucked in and are real wide.
Old 12-05-2014, 05:02:08 PM
JIMnWV's Avatar
JIMnWV JIMnWV is offline
eMail NOT Working
Appears to have a cap on the exhaust, that's a plus.
Old 12-05-2014, 09:19:56 PM
Matthew Guy Clarke Matthew Guy Clarke is offline
I just bought one with tracks around 7' ? wide.
I would like to know the year and model. Smart phones won't do pics.
Old 12-05-2014, 09:45:18 PM
There were 4 different width HG crawlers made. The 31 inch, 42 inch, 60 inch & 68 inch for cultivating. The first HG models were made in 1939, The last in 51 or 52. So with what you asked nobody can tell what year it is. Did you look for a serial number tag?
The Following User Says Thank You to John Schwiebert For This Post:
Old 12-06-2014, 07:18:39 AM
Thanks for identifying the tractor. I hope it finds a good home.
Old 12-06-2014, 04:33:26 PM
My Cletrac is 77 1/4" wide at the outside of tracks, the numbers are HG 68 and 16GAO58.
the frame has a repair to it, and the air breather disappeared after I bought it two weeks ago. I can not say if it was at the sale site, or if it fell off going down the road, I think it went for a walk after the sale, as I drove fairly slow going home.
ID:	212745   Click image for larger version
ID:	212746   Click image for larger version
ID:	212747   Click image for larger version
Old 12-06-2014, 05:41:38 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
That frame repair was fairly common to them. Might be that a air cleaner off a small Oliver tractor would fit.
Old 12-06-2014, 05:47:01 PM
That tractor is a 1945 model. Air cleaner cups and caps are around. It should have the IXK Hercules engine. More questions?
Old 12-06-2014, 08:25:18 PM
Are there parts available? Any weaknesses. I hate to sound incompetant or lazy but they sold a yellow ?? blade over in the weeds for $25. I will always wonder. Were they made with blades or were they made for hitch work? Thanks.
Old 12-06-2014, 08:48:53 PM
FWurth's Avatar
One Millionth Post
The one we had had a front loader on it and was used on a large cattle farm and did all their lot cleaning and silage loading to the feed wagon that filled the feed bunk. They used it many years til the motor gave out and the unit was replaced with a large articulated wheel loader. If the track hadn't been totally worn out they would have simply redone the motor. We fully intended to redo it but better things came along so we got rid of it. The steering is simply breaking one side or the other, there aren't any steering clutches so you have to keep correcting the steering. They are a bit under powered but parts for the little Hercules are still to be found but a bit pricey.
Cletrac F crawler fuel tank ttyR2 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 06-19-2014 08:29:25 AM
Cletrac F Crawler Project ttyR2 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 10-20-2013 07:34:48 PM
Cletrac Oliver Crawler Dozer Nevr-Enuf-Stuf Dozers and Crawlers 4 12-18-2012 10:19:49 AM
Cletrac Crawler w/ ford eng and hood. rails Antique Farm Tractors 5 04-26-2011 06:44:49 PM
Info on Oliver Cletrac crawler 1907Waterloo Antique Farm Tractors 6 12-29-2008 11:40:38 AM
