Myrick Jr?
this thread has 3 replies and has been viewed 1276 times
Old 01-18-2015, 01:41:12 PM
Mike Shaffer's Avatar
Mike Shaffer Mike Shaffer is offline
Default Myrick Jr?
I recently picked up a small 1 1/2 HP Myrick Eclipse engine. I am assuming its an early Jr. as it has a cast brass tag and S.N. 489. I checked the Myrick Registry site and it Is the lowest SN of the 1 1/2 HP engines. Did they not call them JR's until they went to the stamped tags? Anyway thought I would share a few pictures.
ID:	216240   Click image for larger version
ID:	216242   Click image for larger version
ID:	216243   Click image for larger version
Old 01-18-2015, 05:27:27 PM
PaulGray's Avatar
PaulGray PaulGray is offline
Default Re: Myrick Jr?
Nice Junior In unmolested shape Mike! I do believe you are right about the Junior moniker being only on the stamped tag versions. It's weird that the stamped tags on the larger engines appear to surface around s/n 1000 as I recall. I wonder if the muffler is original? Are there any markings on it? Alway nice to see another small myrick surface.
The Following User Says Thank You to PaulGray For This Post:
Old 01-18-2015, 07:38:27 PM
Paul,
I can't confirm the muffler is original to the engine or not as I don't know what the original looked like. I know it looks like its been on there for a long time. Maybe somebody that knows will chime in.
Mike
The Following User Says Thank You to Mike Shaffer For This Post:
Old 01-19-2015, 12:33:22 AM
Jeff R Parks's Avatar
Jeff R Parks Jeff R Parks is offline
Nice original Jr. Mike, looks correct right down to the mount. Attached is a picture
of mine, serial no. 496. Very close to yours, notice the difference in the tag.
Jeff
Name:	Myrick Jr # 496 002.jpg
Jeff Parks
www.parksmotors.net
The Following User Says Thank You to Jeff R Parks For This Post:
Myrick 4hp turnwaldw Oil Field Engines & Related Equipment 17 11-27-2013 03:31:03 PM
Myrick jr Janet Mohney Hit & Miss Gas Engine Discussion 4 04-15-2013 12:08:21 PM
Myrick Eclipse 4 HP value$? Jonah Close Oil Field Engines & Related Equipment 1 10-11-2012 09:06:45 AM
Myrick fun Tom Sampson Hit & Miss Gas Engine Discussion 5 10-25-2009 11:54:08 PM
I want one a these!! An Odd Little Myrick Eclipse Brian Lynch Hit & Miss Gas Engine Discussion 17 12-11-2007 09:53:55 PM
