Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Lister TS2 generator?
this thread has 4 replies and has been viewed 1724 times
Old 03-10-2015, 10:30:13 PM
bbatt bbatt is offline
Default Lister TS2 generator?
Well I made spontaneous buy on a TS2. My SR2 needs a lot of work and I have been keeping my eye out for used or cheap parts, but haven't found much.
I came across this running TS2 for $450 and couldn't resist. I don't know much about it except it came out of a light plant. It has a 8000 KW Dyna Generator head on it that isn't working, so now I am looking for a generator.
I'll pull the heads this weekend and take a look at the cylinders, and valves.
What generator end would be a good fit? I am thinking maybe a Samford if the motor doesn't need much money put into it.
Old 03-10-2015, 10:39:10 PM
ckelp ckelp is offline
Default Re: Lister TS2 generator?
have to checked if it was just an extension issue and not the windings?
a capacitor is a bit cheaper then a new alternator
Old 03-10-2015, 10:57:23 PM
No, I haven't I'm really limited in electrical skills.
Old 03-11-2015, 12:02:45 AM
light it off check the voltage, if it's putting out acuple volts on each leg then the stator is good
try the corded drill trick, with it running and pulling the trigger spin the motor on the drill, try it a couple time see if it takes off on it's own
i'm going out on a limb and say check the and see the capacitor, take 12 volts and just tap the connectors then start it see if it puts out power
if this that dose not work take a pic of the data tag and with the cover off it show us the components
btw i can throw a rock at your house
The Following User Says Thank You to ckelp For This Post:
Old 03-15-2015, 09:37:08 PM
I had a chance to pull the valve covers along with the exhaust, and intake manifolds yesterday. It looks like its in pretty good shape. I didn't bother pulling the heads, because the exhaust manifold was very clean, and if I was to guess has low hours on it. It came out of a Terex light plant and almost all the bolts haven't been cracked since it was painted.
I'll have to check out the generator and see if its just capacitor or the alternator. Anyways thanks ckelp.
lister generator malshel Smokstak Down Under 0 05-16-2014 05:09:48 AM
Lister D and Generator wolseley phill Antique Engine Photos 4 08-13-2013 05:22:28 PM
Lister generator jeholden Vintage Diesel and Oil Stationary Engines 1 08-12-2011 05:20:54 PM
Lister 12/2 30kw koler generator head COOLING The Lister????? mytickets Vintage Diesel and Oil Stationary Engines 2 04-12-2010 04:34:18 PM
Lister generator B. K. Lahey Vintage Diesel and Oil Stationary Engines 0 10-11-2008 05:17:45 AM
