Delco #1278
this thread has 1 replies and has been viewed 1102 times
Old 08-18-2002, 08:15:27 AM
Greg
Default Delco #1278
Finally got it running. Now I need to increase my search for external parts. Does anyone know were I can get a crank for it? I have a repoduction Aluminummmmm one but it tends to wear real fast. Also looking hard for other parts for it if some one has one laying around for parts.
Have pictures of it the way I got it on my home page.
http://users.tc3net.com/ace1811
Old 08-19-2002, 12:04:11 AM
Don C. Wiley
Default Re: Delco #1278
Greg;
I have a crank for all of the Delco-Light generators I have that use one. The Little Joe's used a rope. I have all the cranks fastened to a display board in my shop and I never use them. They were only used when you were dumb enough to allow your Delco-Light battery to go dead or so low it wouldn't start the motor. That's one reason I have Delco-Light generators, just push a button and off you go. No skinned hands and sore shoulder muscles.
I can see by your picture that the coil on your 1278 has the voltage droping resistor on it. When properly hooked to a 32 volt battery the reisistor drops the 32 volts to around 4 volts to opperate the coil.
If you have the unit properly hooked to a 32 volt battery the DC generator serves as a DC motor/starter. No need for a crank. Just lift up on the lever below the cut out coil on the control panel and the motor will be turned about as fast as when it is running. That is if your battery is at least 75 percent fully charged.
I think I have a manual for a Model-1278 but I'm not too sure of that. I don't have the time now to check, but I will try to do that in the next couple of days. That one was a little different than most because it was designed to charge the batteries or to run a line shaft. It has an adjustable governor on it. You were supposed to disconnect the electric load before you used it to opperate the line shaft. It didn't have enough horse power(2-1/2) to do both at the same time.
Have fun and drive safely!
"DELCO DON" Southern Illinois
Delco 1278 Mobile Mechanic Delco and other Low Voltage DC Light Plants 3 12-30-2018 10:50:04 PM
Delco-Remy/AC-Delco Dist/Gen/Starter Etc Numbers Bud Tierney Antique Autos and Trucks 0 01-05-2015 05:09:03 PM
"DELCO DON" Delco 750 starter motor? Arthur Z Generators & Electric Motors General Discussion 1 05-05-2008 12:04:27 AM
Delco Help Gary Wolf Generators & Electric Motors General Discussion 1 03-30-2007 01:38:13 PM
Delco 1278 C. Props Delco and other Low Voltage DC Light Plants 9 05-21-2002 06:17:53 AM
