Wisconsin Engines
My 1972 AENLD with water pump
this thread has 1 replies and has been viewed 934 times
Old 04-10-2016, 03:49:14 PM
johnnyrock70 johnnyrock70 is offline
Default My 1972 AENLD with water pump
Craigslist pick up today. Came mounted to a cart.
Trying to find out more about this pump. I found a tag that says Peabody-Barnes.
Does anyone know if these pumps have a good or bad reputation? Also, once I get it running does anyone know if it is safe to run this without being hooked up to water?
Link:http://s537.photobucket.com/user/joh...?sort=3&page=1
Old 04-10-2016, 05:13:58 PM
Default Re: My 1972 AENLD with water pump
Excellent pumps made in Mansfield Ohio. We sold them for a while. Highly respectable pump mfg. It's not good to run the engine without some water in the pump body as is's what lubricates the seal. Yours appears to have a check flapper on the intake. This, when it seals off, allows you to fill the pump body with water, and hopefully it will self prime. Otherwise, you'd need a foot valve on the end of the suction hose and fill all with water before pumping.
Military Wisconsin AENLD, Carver pump trowel Wisconsin Engines 4 03-11-2014 03:25:24 AM
Deane steam pump co. water pump video Nick McCue Hit & Miss Gas Engine Discussion 4 07-05-2013 04:53:17 PM
Deane steam pump co. water pump info needed Nick McCue Hit & Miss Gas Engine Discussion 2 08-07-2011 06:59:51 PM
Water Pump no water Fairbanks Morse lowboy Farm Antiques and Collectibles 1 06-14-2011 09:33:24 PM
Onan 30EK city water model water pump impeller? Pete Spaco Onan Generators 9 06-12-2011 02:36:49 PM
