Gilson Questions
this thread has 8 replies and has been viewed 615 times
Old 07-24-2016, 12:35:46 PM
Jack Innes's Avatar
Jack Innes Jack Innes is offline
Default Gilson Questions
TWO engines Many Questions
1. I have found a 6 hp Gilson Wizard made in Guelph with what looks like a 1926 dated serial no. Where might I find a valve rocker arm (or a pattern), a Webster mag bracket & a gas tank to fit this engine?
It turns over & has no cart. What might be a fair price for such an item?
__________________________________________________ __________
2 . I have the Gilson engine pieces pictured. Everything else was thrown out by the clean up crew of an old man's estate. I would like to put the engine back together for the sake of the family. Is there any hope of finding a frozen up engine or parts to complete this one? The governor side flywheel has hub problems as well.
The hopper has an amazingly well done repair near the bottom. Where on the flywheel will I find the serial no.? Does it look like a Canadian engine?
ID:	258836   Click image for larger version
ID:	258837   Click image for larger version
The Following User Says Thank You to Jack Innes For This Post:
Old 07-24-2016, 01:51:49 PM
Email NOT Working
Default Re: Gilson Questions
That's at least FIVE questions maybe 8 :-)
but I appreciate you sharing the story with us and especially with pictures. I would contact the Magneto men who are sponsors on this site and find out the Webster mag bracket number and availability.
Finding a recast rocker arm I wouldn't think would be too difficult. I'm not a Gilson expert but Denis Rouleau is.
I'm sorry I can't be more help but all help keep your post alive until he sees it! Nice engine, it will be great for the family to see it running.
The Following User Says Thank You to Kevin O. Pulver For This Post:
Old 07-24-2016, 05:20:58 PM
M Wilson M Wilson is offline
The engine in your pictures look a twin to a Johnny on the Spot I just got running, right down to the hopper repair. I found my serial number on the crank guard (sheet metal) some are cast. But others had the number stamped into the outside of the flywheel.
The Following 2 Users Say Thank You to M Wilson For This Post:
Old 07-24-2016, 06:13:25 PM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Originally Posted by Jack Innes View Post
[COLOR="Red"]
Only 1004 Gilson Wizard engines were built all in Guelph, Ontario. They were first introduced around 1920. They were built in 4 sizes, namely 1-3/4hp, 3-1/2hp, 6hp. and 10 hp. Most of the Wizards were of the 3-1/2hp and 6hp sizes. I used to have all 4 sizes but they are all gone now and I have no parts for them.
Look at the registry here: http://buzzcoil.brinkster.net/gilson/page524.html
The serial number can only be found on the name tag. What is the serial number on this Wizard?
Denis Rouleau
The Following 2 Users Say Thank You to Denis Rouleau For This Post:
Old 07-24-2016, 07:12:16 PM
Jack Innes's Avatar
Thank you for the information Denis. Since I do not own the 6 hp engine yet I do not feel comfortable posting the ser. no. PM sent.
Jack
Old 07-24-2016, 07:52:43 PM
1. It turns over & has no cart. What might be a fair price for such an item?
With these important parts missing the maximum I would pay is $750.00.
Denis Rouleau
The Following User Says Thank You to Denis Rouleau For This Post:
Old 07-24-2016, 09:19:10 PM
Mike Unwin Mike Unwin is offline
Are you sure it is a 6 HP ? What diameter are the flywheels ? Looks like a 1 3/4 hp Johnny course I could easy be wrong . If it is the smaller size should not be to hard to find parts. Cheers and Good Luck Mike
Name:	Gilson 1.75 hp.jpg
The Following User Says Thank You to Mike Unwin For This Post:
Old 07-24-2016, 10:05:18 PM
Jack Innes's Avatar
Mike,
My posting was about Two engines #1. is a 6 hp Wizard; #2. is the smaller incomplete engine in need of parts that were thrown away. It is likely a 1 3/4 hp as you said. Do you know of any parts available around here? (I am near Brooklin)
Old 07-24-2016, 10:17:55 PM
Sorry I misunderstood Jack . This is one I have heard about .http://www.kijiji.ca/v-cars-other/oa...ationFlag=true
10 HP Gilson Robert Massey Hit & Miss Gas Engine Discussion 7 08-27-2014 09:12:59 PM
Gilson timing questions... Edwin Hit & Miss Gas Engine Discussion 12 04-05-2012 03:56:16 PM
Montgomery ward/ Gilson and Onan questions Ken Karrow Garden Tractors and Mowers 1 08-01-2010 09:50:34 AM
Gilson questions R. Kern Hit & Miss Gas Engine Discussion 4 01-18-2009 10:46:51 PM
Is this a Gilson ? Mike bisbee Antique Engine Archives 3 01-28-2003 05:58:51 PM
