Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
5.4hp Zephyr Outboard
this thread has 12 replies and has been viewed 518 times
Old 05-02-2019, 01:33:59 PM
Jim Hearn Jim Hearn is offline
Default 5.4hp Zephyr Outboard
I have what I think is a 1948 evinrude zephyr that my father in law painted some affual color right before he died about 25 years ago, and I am starting to piddle around with it and I would like to know the original color of this motor. It runs and looks good except for the color. any help would be appreciated, oh and Hi all I just found the forum and it looks like an informative place to visit.
Old 05-02-2019, 09:28:36 PM
JoeCB JoeCB is offline
Default Re: 5.4hp Zephyr
The Evinrude Zephyr is a very interesting little outboard. Four cylinder opposed , 5.4 HP. The carburetor set -up is very complicated, with primer pump, external tank vent and vent shut-off. As for color, must all of the motor was painted dull aluminum. the post war models had the fuel tank painted a teal blue color. 1949 was the last year for the Zephyr.
For more info, post your question at "ask a member" on aomci.org.
There is a paint supplier that serves the antique outboard community that has exact color match paint for just about all the old outboards... Reprotint
Joe CB
Old 05-02-2019, 11:07:28 PM
thanks
Old 05-02-2019, 11:09:56 PM
ulgydog56's Avatar
jim show use a pic if you can, love the old stuff...
Old 05-02-2019, 11:44:56 PM
Jet Provost Jet Provost is offline
I have an original Zephyr. Sort of a base silver with green tank accents. I will get pictures. Sort of buried behind airplanes. Also not many left. Most caught on fire and were pitched in lakes. Fabric plug wires snaked around the carburetor did not always workout.
Old 05-03-2019, 05:13:01 PM
Ok, Here you go
ID:	334043   Click image for larger version
ID:	334044   Click image for larger version
ID:	334045   Click image for larger version
Old 05-03-2019, 09:52:03 PM
Jim, that is a nice looking Zephyr, it looks like in real nice shape and original , un-molested. They are sweet runners, exceptional smooth idle. Just a caution on the spark plugs. The original plugs are Champion J6J the current equal is a J6C. Same heat range but the plug is a bit longer which puts the wire terminal a little closer to the inside of the front cowl cover, perhaps affording an opportunity for a spark to jump to ground. With carb and gas under that cowl , I don't like any stray sparks. The plug that I use in my Zephyrs with good results is NGK BM7A, same heat range but with a shorter overall length and a screw -on wire terminal.
Joe B
Old 05-03-2019, 11:13:35 PM
Thanks, the plugs in this one are 6JC, This motor has always had problems with the plugs or wires shorting out and causing at least one plug to foul. I am thinking about trying to shield these parts some way to avoid this, and by the way I am looking into a 3 or 5 hp Johnson made in the early 50's, but I would like one that you can start in neutral. But i am not sure what year they put a numeral gear in these motors.
Old 05-04-2019, 06:40:34 PM
Jim, you are looking for a Johnson 5 hp model TN ( N= neutral) .
This pretty common green Johnson was made from 1950 thru 53.
If you have an interest in old outboards , sounds like you need to come out to one of the AOMCI meets where there is normally a swap & sell.
Joe B
Old 05-04-2019, 11:08:57 PM
Thanks, I just received my copy of "The Old Outboard Book" and it has a lot of info about these motors. And the next AOMCI meet near me is June 8 at Lake Houston.
Old 05-05-2019, 04:00:35 PM
I was wrong about the spark plugs, they are J7J plus.
Old 05-07-2019, 12:00:48 PM
Default Re: 5.4hp Zephyr Outboard
Here is mine. Original paint. Still shines.
Old 05-07-2019, 05:02:44 PM
Looks good, I took off the fly wheel just to inspect what i could see and it all looks good. Do not have any idea of how to set the points or anything else. and it has a bunch of clay like material covering a bunch of small wires going under the plate the coils and points are attached to. I may need to get the book to figure out what is going on under the fly wheel. This is what it looks like
ID:	334326   Click image for larger version
ID:	334327   Click image for larger version
ID:	334328   Click image for larger version
Evinrude Zephyr GlenK Antique Marine Engines and Outboard Motors 1 04-29-2018 12:09:45 PM
Outboard, Evinrude , Zephyr Models 4359, 4361, 4362, 4363, Lightfour Models 4375, 437 TractorDom Antique Marine Engines and Outboard Motors 1 02-16-2016 08:28:03 PM
evinrude zephyr coils wedge Antique Marine Engines and Outboard Motors 1 09-01-2014 09:52:49 PM
Chester Zephyr 2ton hoist, ser.# EXT729 Dwayne Oxford Machine Shop and Tool Talk 0 05-24-2013 10:10:17 AM
Lincoln Zephyr V12 coils kerogas Antique Autos and Trucks 4 03-07-2008 11:11:01 AM
