Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Unidentified Twin Cylinder Inboard Marine Engine
this thread has 5 replies and has been viewed 689 times
Old 05-19-2019, 01:17:51 PM
CaseyJoeS.'s Avatar
CaseyJoeS. CaseyJoeS. is offline
Default Unidentified Twin Cylinder Inboard Marine Engine
I received these two photos third hand through some friends. It is being cleared out from an old basement from what I understand. Can anybody identify the make and model of this engine, and an approximate value in average condition? This is out of my wheelhouse but I plan to get my hands on it so that I can make sure it gets to a collector and not in a dumpster
ID:	335148   Click image for larger version
The Following 3 Users Say Thank You to CaseyJoeS. For This Post:
Old 05-19-2019, 01:44:04 PM
Default Re: Unidentified Twin Cylinder Inboard Marine Engine
Evinrude inboard, it should be written behind the fuel tank. The timer is rigged, should have a magneto ignition, most of them failed. It's a small engine which seems to be easier to sell, if it has compression it's worth more, no mag will hurt the value. Google Evinrude inboard for pictures.
The Following 3 Users Say Thank You to J.B. Castagnos For This Post:
Old 05-20-2019, 12:43:30 AM
softy42 softy42 is offline
Yes, Evenrude ! Will it be for sale ? I'm very interested. Thks Des drcowie@powerup.com.au
Old 05-20-2019, 11:50:53 PM
ulgydog56's Avatar
now that's cool....
Old 05-21-2019, 07:00:02 PM
JoeCB JoeCB is offline
Hard to tell from the Pix but looks like an Evinrude flywheel magneto to which some juryrigged timer/points have been added.
A front view photo would help.
Joe B
Old 05-21-2019, 07:30:37 PM
I had a similar engine tagged WAJAX built in Newark NJ. Looked the same as the Evenrude, it was used on portable fire pumps.
Twin cylinder marine skeleton. What is it? B.L. Rodenkirch Antique Marine Engines and Outboard Motors 7 06-09-2017 02:28:03 PM
My crummy Lauson RSM 826 Inboard marine engine mschreiber Small Air Cooled Gasoline Engines 9 02-20-2017 09:32:35 PM
Antique inboard marine engine - help i.d. okmnx01 Antique Marine Engines and Outboard Motors 3 12-26-2015 07:25:37 PM
Inboard Marine engine Timer? Jim Martin Antique Marine Engines and Outboard Motors 2 03-08-2013 01:14:13 PM
unknown twin cylinder marine,looks similar to a gray nat Antique Marine Engines and Outboard Motors 1 07-07-2012 07:15:54 AM
