Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
johnson seahorse model ms38 sausage tank?
this thread has 3 replies and has been viewed 240 times
Old 08-16-2019, 03:13:11 PM
ulgydog56's Avatar
Default johnson seahorse model ms38 sausage tank?
free to me..1938 Johnson seahorse model ms38 serial # 300621.what spark plug and gap do I run on this and points gap and if i'm real lucky where to find a carb rebuild kit also what are the carb settings and any other infro I can get on this, I would appreciate any infro on this fella's ,just got it and want to clean her up and get it running right.....thanks ...
ID:	341576   Click image for larger version
ID:	341577   Click image for larger version
Old 08-16-2019, 11:26:12 PM
JoeCB JoeCB is offline
Default Re: johnson seahorse model ms38 sausage tank ?
Johnson MS38 >>> 1938 , 1.1 HP use Champion J8 (C) plug gap .030 , point gap .020. Oil 1/2 Pt per gal. As for the carburetor , no "kit" required, just take the fuel system apart and clean real good. I believe that that fuel tank is copper, so should be no rust. The ignition coils on these old Johnsons are usually OK, may need to replace the condenser. Get er' running .
Joe B
The Following User Says Thank You to JoeCB For This Post:
Old 08-16-2019, 11:50:35 PM
ulgydog56's Avatar
thanks joe, I see your close by me. do you know the carb main and idle screw valve start settings. and start procedures..
Old 08-17-2019, 11:10:01 PM
ulgydog56's Avatar
had to solder new plug wire to coil and go thru most everything (got spark) i'll see if she fires off tomorrow ...
Johnson 5.5 Seahorse Recoil Help Dustin D Ehli Antique Marine Engines and Outboard Motors 4 07-20-2019 09:52:59 AM
info on a Johnson Seahorse TS20 joder Antique Marine Engines and Outboard Motors 4 01-05-2015 03:09:37 PM
Johnson Seahorse TN26 Zen Antique Marine Engines and Outboard Motors 8 01-05-2015 02:46:56 PM
Johnson Seahorse Model TDL-20 Robert Jackson Antique Marine Engines and Outboard Motors 10 08-21-2013 12:32:50 AM
Johnson Seahorse TD 20 ehpower2 Antique Marine Engines and Outboard Motors 1 04-11-2009 12:31:41 AM
