Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Caille Perfection inboard motor
this thread has 4 replies and has been viewed 339 times
Old 08-22-2019, 04:36:09 PM
Allstans Allstans is offline
Default Caille Perfection inboard motor
Looking for a water pump for my Caille inboard engine (from about 1913 I guess). When the pump broke, many years ago, it was cut off and replaced with a gear pump. Now that I want to change to the original pump, I can't find it. The pump should sit on a triangular plate at the back of the cylinder. The plate is now modified for water hose from the current pump.
Don't know the number of horsepower, the cylinder diameter is 5.5 inches.
The engine sits in an old wooden boat and is still used, for nostalgic reasons.
Thankful for information about the engine and where I could possibly find an original pump.
Writing from Sweden and Google has helped me with the English translation
ID:	342039   Click image for larger version
ID:	342040   Click image for larger version
The Following 3 Users Say Thank You to Allstans For This Post:
Old 08-22-2019, 09:16:25 PM
John Davis's Avatar
John Davis John Davis is offline
Photo Re: Caille Perfection inboard motor
I can not help you with parts but maybe someone on the forum can. Below are some link's and photo's of a few Callie inboard Marine engines. Photo's might help with knowing what your pump should look like. Also a link to a few Caille advert's.
http://www.antiquengines.com/CPMC_Ma...ine_Photos.htm
http://www.antiquengines.com/CPMC_Ma...Literature.htm
ID:	342061   Click image for larger version
ID:	342062   Click image for larger version
The Following 2 Users Say Thank You to John Davis For This Post:
Old 08-22-2019, 09:18:51 PM
Default Re: Caille Perfection inboard motor
www.oldmarineengine.com
Old 08-22-2019, 11:56:45 PM
JoeCB JoeCB is offline
The oldmarine engine site is likely your best chance. If nothing comes from there, post a "wanted ad " on aomci.org Many Caille fans there for both outboard and inboard motors.
As an aside, The Caille company building on Second Ave. in Detroit is still there.
Joe B
The Following User Says Thank You to JoeCB For This Post:
Old 08-23-2019, 03:00:55 PM
Thanks for quick reply and links etc.
It is the outside diameter of the cylinder that is 5.5 inches, see the attached image.
Caille Perfection farm engine paul midgley Hit & Miss Gas Engine Discussion 3 04-15-2010 10:31:09 PM
Caille Perfection motor co. JLB1111 Antique Marine Engines and Outboard Motors 2 12-15-2008 08:20:56 PM
Caille Perfection Foos Jr Hit & Miss Gas Engine Discussion 9 02-04-2006 04:37:32 PM
Caille Perfection Engine NMidgley Hit & Miss Gas Engine Discussion 0 06-23-2005 12:07:59 AM
Caille Perfection J. Marti Antique Engine Archives 1 03-10-2002 10:23:14 PM
