IHC Famous 3hp vertical
this thread has 5 replies and has been viewed 2007 times
Old 10-03-2006, 08:11:26 PM
Dave T
Default IHC Famous 3hp vertical
Hello all
I just picked up a vert.3 hp tank cooled famous today, got her running first crank, but the water pump is not operating the way it should.
It had not been run for at least 4yrs.
I oiled the water pump piston prior to starting.
Any suggestions as to what I might have to do to get her pumping properly??
Thanks in advance
Dave
Old 10-03-2006, 08:44:51 PM
Brian Tefft Brian Tefft is offline
Default Re: re famous 3hp
Unscrew the fitting on top of the pump and make sure the check balls are not stuck. Brian
Old 10-04-2006, 04:51:36 AM
Sometimes you need to prime it just to get it started. I have a "T" fitting on top of my pump with plug on top that I use to prime it. Make sure the lever that is used to drain the water is in the correct position or you can run it all day and get nothing. If that doesn't work try post # 2
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 10-04-2006, 11:00:49 PM
Dave T
Smile Re: re famous 3hp
Thanks for the tips lads will try that tomorrow
Dave
Old 10-08-2006, 08:30:12 AM
Dave T
Thanks for the tips
I took the pump off the engine and took it all apart and the inlet was pluged solid with crud, cleaned up the top leather and repacked the piston flange nut and then I got water, have to install a Tee on top to prime when needed.
Thanks again
Dave
Old 10-09-2006, 03:14:34 AM
Thumbs up Re: IHC Famous 3hp vertical
IHC Famous 3HP vertical stevenkd5017 Hit & Miss Gas Engine Discussion 6 09-26-2012 08:09:13 PM
IHC famous 3hp vertical stevenkd5017 Hit & Miss Gas Engine Discussion 5 08-25-2012 10:25:16 AM
2 hp vertical Famous? Johnny T Hit & Miss Gas Engine Discussion 20 01-10-2008 10:20:40 PM
3hp Vertical Famous LW Antique Engine Archives 14 06-03-2004 10:39:03 PM
IHC FAMOUS VERTICAL Joe LeBlanc Antique Engine Archives 2 06-05-2002 09:12:22 PM
