Welding Shop
Lincoln Lincwelder 225
this thread has 10 replies and has been viewed 16530 times
Old 07-07-2007, 09:57:11 PM
ncflatfender ncflatfender is offline
Default Lincoln Lincwelder 225
I've been given the opportunity to buy a Lincoln Lincwelder 225 for $40.00. I looked at it today and it is whole and looks to be a viable machine. My question is does anyone know when they built these machines? I have seen reference to them going back to the '40s through 1970. I'm not sure if it is wise to try to refurb a 1940's welder. Does the shellac winding insulation goe bad? Is the armature on the generator part carry risk because of age? Thanks for any input. Scott
Old 07-07-2007, 10:13:20 PM
Franz
Default Re: Lincwelder 225
For $40- how the hell can you go wrong if it runs & generates.
Look over the commutator end for broken varnish and lashing before you start it. Check the windings and wiring for shorts to ground too.
Then start it and see what you have.
There are one hell of a lot of lincolns built in the 40s still running and making money for their owners. Those machines were built by craftsmen who could and did make more money per week than some doctors. James T Lincoln put the responsibility for quality on the man who built the machine, and till 20 years ago every machine could be traced back to the man who built it.
Old 07-07-2007, 11:37:20 PM
Thanks Franz, I am into old machines but I wasn't sure if this was a waste of effort. I have a Lincoln mig welder that I love but I want to stick weld also. You have been a big help. Scott
Old 07-08-2007, 01:39:02 AM
Franz
You may actually be able to get a lot of info on the machine at www.lincolnelectric.com but you'll need the nameplate numbers.
Old 07-17-2007, 05:55:41 PM
Default Re: Lincoln Lincwelder 225
I was given a 225 AC by a close friend that was like a Grandfather to me. I rebuilt the welder and called Lincoln with a few questions on it and the man put me on hold and came back and told me that he went to go check the parts on the machine that I had and he had three new face plates left for my model and I bought one and it was $14.00 plus shipping. I was amazed that he remembered seeing it on the shelf and that they even had one for an early 1960’s vintage machine. It was nice to replace the faceplate because now it looks similar to when it was a new machine. The man was also very knowledgeable about Lincoln welders and answered all of my questions leaving me with a good feeling about what brand welder I would purchase next time. I have used this machine a lot and am very pleased with it. The man that gave it to me used it for decades on his farm and was pleased with it also. I do not think you will go wrong with an AC machine for $40.00, but please remember that it is not a DC machine and there will be times that you might wish that you had one.
Jeff Smith
Old 07-18-2007, 08:26:58 AM
Hi Jeff, I'm a little confused now. It says on the faceplate that it is a DC welder with AC outlets. I got it running and it is putting out ac to the outlets but it has 32 voltsDC to the output pins for my leads. This is too high I believe but I haven't had a chance to look into why it is so high. I believe it should be about 14v-15v DC.
Old 07-18-2007, 08:55:18 AM
That should have been 14v-25v DC
Old 07-18-2007, 10:45:14 AM
Franz
Read the arc voltage with the machine actually burning a rod.
Open circuit voltages mean nothing on the arc side.
Old 07-25-2007, 08:05:07 PM
Hey Franz, thanks for the advice on going for this welder. I cleaned the fuel pump and carb and drained the old gas. I cranked it up tonight and it ran smooth. It also welds. I used a 30 year old stick but it still struck an arc and welded. Scott
Old 07-25-2007, 08:53:29 PM
John A John A is offline
Heck, for $40.00 bucks if it don't work, sell the copper for scrap. Should easily get your money back.
A buddy of mine has an old Lincoln, I mean old, and it burns a fine bead.
I personally would rather have an old school, quality made in the U.S.A. piece of equipment than the stuff out there today.
God Bless America!
Old 03-18-2008, 09:51:48 AM
ChadPatten ChadPatten is offline
I just bought one of these welders myself and I need some help. It seems to run and weld very well, but my ac plugs only show 20-30 Volts at high rpm. It also has the setup for two batteries but all the wiring is screwed up and I need a diagram to help me run new wires. The diagram is gone off the inside of the hood where is should be.
Any input is greatly appreciated.
Chad
lincoln lincwelder 225 opinions. and pictures needed. Oddballmotorsports Welding Shop 1 09-12-2016 08:37:52 PM
Lincoln lincwelder 225 Varmint1 Welding Shop 0 09-07-2016 07:27:29 AM
Lincoln lincwelder 225 Varmint1 Welding Shop 0 06-26-2016 10:32:36 AM
Hello from Yonkers, Georgia! (Lincoln Lincwelder) JohnWT Welding Shop 0 03-09-2014 10:07:09 AM
2 Lincoln Lincwelder 225s for sale ChrisR Welding Shop 0 03-17-2006 07:00:01 PM
