Need HELP! Making endless belts
this thread has 3 replies and has been viewed 3372 times
Old 09-23-2007, 10:26:45 PM
Rick McKay Rick McKay is offline
Default Need HELP! Making endless belts
Hi everyone,
I would like some input about making endless belts. I have a heated press for cooking the glue, but don't know what type of glue to use, and what type of belting will work for endless belts. Also I would like to know the best procedure for preparing the glue joint.
Any help/advice would be greatly appreciated, I have a planing mill with a tendency to tear out clipper lacings, and would like to try something different. My Clipper belt lacer is getting worn out from all the belt-fixing that goes along with that machine!!!
Thanks,
Rick
Old 09-24-2007, 10:25:56 AM
Default Re: Need HELP!! Making endless belts
Two long, angled skives are made....one on each side of the belt, looking like a capital N except overlapping, to provide for a long angular glued or vulcanized joint.
I kind of doubt this is something you can do yourself.......
The only other alternative is a new belt rated for hammer mill service which is the toughest service to which a belt is subjected.
Short of a spliced belt the only other is a compass belt which is woven at the factory in one continuous piece, is truely endless.......and VERY expensive.......
Old 09-24-2007, 01:22:53 PM
Default Re: Need HELP! Making endless belts
Thanks Craig,
I was wondering if anyone knows what type of machine is used to do the skiving process.....is it an abrasive type of action or slicing? Since I have my own glue press, I would like to make the belts in place so that I don't have to dismantle the machine to install them! I just have never found anyone that has made endless belts that can enlighten my feeble mind .
Thanks again,
Rick
Old 09-24-2007, 01:28:15 PM
Rick.....try calling someone here: http://web.applied.com/
If you can't get any decent answers give John Waldvogel a call at the Wausau, WI, branch!
He's a great guy and I'm SURE he'll answer your questions.......
PH: (715) 359-2265
Craig
Making power belts from leather RustyNumbat Farm Antiques and Collectibles 13 03-20-2019 05:06:00 AM
Endless Tread Dirtdobber Garden Tractors and Mowers 1 07-24-2012 12:19:29 PM
Endless Tread Tractor Tom WV Garden Tractors and Mowers 5 07-24-2012 12:17:19 PM
Endless Search vampire13 Onan Generators 2 02-28-2011 04:58:05 PM
Making flat belts from conveyer belts Ihorse Hit & Miss Gas Engine Discussion 7 12-03-2005 11:01:16 PM
