Welding Shop
Welding Steel to Cast Iron
this thread has 20 replies and has been viewed 57170 times
Old 02-05-2008, 02:32:47 PM
Dustin D Ehli Dustin D Ehli is offline
Default Welding Steel to Cast Iron
Everyone is going to hate me for bringing the old welding cast iron topic up again, but i may be purchasing an engine that has the rocker arm bracket broken off and it is missing, if i made one out of steel could it be successfully welded to the cast peice where the old one was or am i a moron
Dustin
Old 02-05-2008, 03:29:43 PM
Patrick McNallen Patrick McNallen is offline
Default Re: Welding steel to cast iron
You could probably braze it. If the head isn't rare, I'd try to find a replacement.
Old 02-05-2008, 04:39:57 PM
Mike's Avatar
Mike Mike is offline
I would make one out of wood, mail it to one of the cast iron foundries and have the part cast out of grey iron, then braze it on to the head. It would look better than the steel part.
Old 02-05-2008, 07:05:24 PM
use normal prep procedures and weld with machinable nickel,short welds and peen well.
Old 02-05-2008, 09:11:01 PM
VicP's Avatar
VicP VicP is offline
Photo Re: Welding steel to cast iron
I have a similar dilema A Maytag shaft journal missing an ear. A previous repair done with braze. I was thinking of making the missing part from steel
(easier for me) and using a nickel rod to attach ?? I would appreciate your
thoughts here thanks Vic
ID:	29093   Click image for larger version
Old 02-05-2008, 09:47:53 PM
Brian Riddle
The best thing to use is spray welding nickel would work and so would brassing it but in my opion you get the best out come with welding cast is spray welding. if you are going to do it right in my opion and save your self the head ach of worring if it is going to hold just repour it maybe you can bowwor one from someone.
I am no expert but this is what worked for me in the past.
I have weld lots of cast it ant fun
Brian
Old 02-05-2008, 09:52:25 PM
vern0n's Avatar
vern0n vern0n is offline
I've welded steel to cast using Ed's method.
Old 02-05-2008, 10:29:43 PM
VicP's Avatar
Ed
Could you please elaborate on the term "peening" in this operation Thanks
Vic
Old 12-23-2008, 09:26:25 PM
arkot arkot is offline
Dustin
Peening is actually " hot peening".
Hot peening is used for repair welding of thick parts.Hot peening is done immediately after brushing the slag from the hot weld bead. A light round head hammer is used to flatten the hot weld bead by light and fast blows.
Hot peening reduces the weld stresses, adds to the strength of the weld and increases it's crack resistivity.It converts the cast structure of weld bead into forged structure.As you know forged structure is stronger than cast structure.
The Following User Says Thank You to arkot For This Post:
Old 12-30-2008, 02:51:04 PM
ciggs ciggs is offline
I used Lincoln 99 stainless steel rod works really well for cast, I also used a barbecue to heat the part up and allow for slow cooling.
Old 12-30-2008, 08:08:21 PM
Welding an ear on to a casting isn't as critical as welding a crack in the middle of a cast piece. When you weld a piece on to the end of a casting it can expand and then contract as it cools. When welding a crack in the middle of a casting, it expands as you weld it, when it cools it contracts, since it's contained in the middle of the casting, it will crack on side of the weld. Cast iron is poor under tension, this is what happens when it shrinks as it's cooling. Short welds don't build as much heat, Peening tends to expand the weld to compensate for the shrinkage. Pre heating lets everything expand so that it all shrinks together, this can be difficult on large castings. Welding the steel rocker stand to the cast head should work out OK.
Old 12-30-2008, 08:52:46 PM
Oilzum's Avatar
Oilzum Oilzum is offline
I have TIG welded ears back on cast iron pieces with pretty good success. I agree that the good results may be because the ears are on the end of the piece and not subject to the shrinkage pull like welding a center piece. Plus I find I can control the heat with the TIG much better. JMHO. Your results may vary.
Old 04-15-2009, 10:58:09 AM
aametalmaster aametalmaster is offline
Cool Re: Welding steel to cast iron
Here is a great rod for cast iron and steel to cast iron. It welds nice and is machinable. Crown Alloys 255 ...Bob
http://www.crownalloys.com/page10.pdf
Old 04-15-2009, 07:10:30 PM
Steve Holbrook Steve Holbrook is offline
Default Re: Welding Steel to Cast Iron
If I remember correctly, If it has been Brazed with brass, your going to have to remove all the brass before you weld.
Old 03-14-2013, 10:56:59 PM
Flynt Flynt is offline
Pre heat the steel a little more than the cast. Cast iron cools faster and is more porous than Mild steel. Make small welds(brazes?), And tap it lightly immediately with a small hammer, Or use a chipping hammer and gently tap tiny dent all around the weld it works too, looks ugly but does the same thing. Your objective with tapping it is becuase since cast cools faster than steel you spread the weld and forge it while it is cooling. Good luck!! Id just look on ebay though and look for a head or rockers.
Old 03-19-2013, 04:03:57 PM
Langes Machine Shop Langes Machine Shop is offline
The stongest would be brazing it together. That is welding it with Bronze and a torch. There is no rod that is BRASS, it is bronze there is a big difference!!!!!! Could be welded with a spray torch and cast powder too.
Old 03-19-2013, 09:57:41 PM
IronworkerFXR IronworkerFXR is offline
I would like for somebody to explain to me "spray welding" The only spray welding I have done is at my friends shop with a big 400 amp welder that he adjusts the voltage to set up the MIG gun that pushes out coat hanger size wire for welding buckets with AR400 steel.
at my shop I can powder spray weld with a torch for building up a crank surface to make up for a race, its too hard to machine for a fine finish for bearing contact.
soo what are we talking about here.
also I use my needle scaler to Peen my cast welds along with pre and post heat.
Old 03-20-2013, 04:39:30 PM
It is a powder spray torch, there are many different types of powder that you can use, from Cast iron, bronzochrom,tungtec,so on and so on. Bronzochrom is very nice for seal surfaces once machined it won't wear or rust again. Powders can be a little expensive, so the common person would not want to get into doing this, it takes practice and that costs you in powder and money.
Old 03-20-2013, 05:09:51 PM
ALora ALora is offline
I have welded steel to iron many times by brazing. (acetylene torch). Must be wide dep V as much as possible, much preheat and some post heat. Without some brazing experience it could be tough to do. I would not think about arc weld. Art Lora
Old 03-20-2013, 07:29:20 PM
OTTO-Sawyer's Avatar
I don't know what number the rod was, but I believe Dad always used a Nickle Rod on Iron with an ancient Arc Welder which was always believed to be one of the oldest welders in Northern Illinois.
As far as welding iron and steel together, He did that quite often as well, including welding the iron bull gears on to the steel spokes of the 1/2 scale OTTO tractor that he built back in 1972 which I now own. As far as I know, he used the Nickle Rod for that too.
He also used to split exhaust manifolds for straight six engines to make dual exhaust systems by cutting the iron manifold in half and welding a steel plate on to plug the hole in the end and weld a steel exhaust pipe flange in the middle for the second outlet.
He would occasionally Braze iron too, but most of the brazing I ever saw him do was on sheet metal, patching holes in oil pans and timing chain covers, from thrown rods or broken timing chains, or patch panels on floor pans.
Welding cast iron and steel together. Jim Rankin Blacksmithing and Metallurgy 13 05-14-2015 07:47:53 PM
Cast iron welding Kelly Tytlandsvik Welding Shop 3 02-01-2012 10:24:13 PM
Cast Iron Welding crazycajunred Welding Shop 3 05-16-2011 06:53:51 PM
Welding cast iron off old engines (WITH STAINLESS STEEL RODS) P Grogan Hit & Miss Gas Engine Discussion 36 01-31-2010 04:21:14 AM
To make new valves - cast steel / cast iron Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 05-02-2009 12:53:18 AM
