Welding Shop
Peening while welding?
this thread has 13 replies and has been viewed 18220 times
Old 02-08-2008, 11:09:11 AM
VicP's Avatar
VicP VicP is offline
Default Peening while welding?
I am unfamiliar with the term peening while welding cast iron. I would
appreciate a tutorial on the how and why thanks Vic
Old 02-08-2008, 11:38:20 AM
KeithW's Avatar
KeithW KeithW is offline
Default Re: Peening ??
Odd as it sounds you peen with a ball peen hammer. For welding cast iron you weld a short distance then tap on the weld with the peening hammer. Here is what is happening. When you weld the metal gets really hot and expands. After it gets solid it continues to shrink creating a lot of stress in the metal. This is why it cracks, it gets pulled apart. By peening the weld you are pushing the weld down causing it to expand and releaving the stress. If done properly the weld is no longer under internal tension. You also want to heat the item to be welded to as much as 400 F and cool it slowly after welding.
keithw
Old 02-08-2008, 07:37:51 PM
Ken Majeski's Avatar
Also a Muffer Gun or a Needle Scaler works Good.... But have a pressure regulator hooked in or it Might Peen Too Hard...
Ken Majeski, Ellsworth Wis.
Old 02-09-2008, 12:33:18 AM
VicP's Avatar
Extremely logical advice ! Thanks a lot guys
Vicp
Old 02-09-2008, 11:50:24 AM
Elden DuRand's Avatar
I guess it's the anal retentive in me that makes me ask the question:
Isn't the hammer with a rounded head called a "ball pein" hammer (pronounced "peen") and isn't the act of hammering rivets or welds called "peining"?
It's terrible being a nitpicker. Our lives are so hard.... :-)
Take care - Elden
http://www.oldengine.org/members/durand/
Old 02-09-2008, 03:02:52 PM
KeithW's Avatar
Wink Re: Peening while welding?
Peen in the US, Pein in the UK. Sort of like tire and tyre.
keithw
Old 02-09-2008, 04:42:51 PM
Gene O. Carpenter's Avatar
Gene O. Carpenter Gene O. Carpenter is offline
eMail NOT Working
Default Re: Peening while welding?
You "peen" rivets, welds etc! You "pein" back of the shed when nobody's looking!!!
Old 02-09-2008, 08:04:06 PM
Bill Geyer's Avatar
Now I'm really mad, looks like I've got a British hammer
Old 02-09-2008, 08:35:20 PM
KeithW's Avatar
Talking Re: Peening while welding?
That's alright, my tyre irons have worked fine for years on American tires.
keithw
Old 02-09-2008, 10:36:40 PM
Arthur
Way back when I was burning rods, Lincoln told us the thing making the arc was the welder and the nut that was holding the stinger was the weldor . Some folks have something to say, I just have to say something or I'll have a pain somewhere. Thanks to all for helping me along, Arthur
Old 02-09-2008, 10:40:33 PM
Then there are "gudgeon pins" but we won't go into that.
Take care - Elden
Old 02-11-2008, 10:22:02 PM
VicP's Avatar
This was one wild ride !!! Thanks again guys ;-)
Vicp
Old 03-24-2008, 03:54:08 PM
Phil Phil is offline
I can no longer gudgeoun out behind the shed, beacuse my doctor told me not to lift anything heavy
Old 03-24-2008, 07:34:48 PM
NewportNic's Avatar
NewportNic NewportNic is offline
Being a "Rag Bagger" I recognized gudgeon as a nautical term. I always called the other a wrist pin, my SmokStak education continues...
ID:	31396   Click image for larger version
MIG Welding cobbadog Welding Shop 15 12-22-2017 07:16:57 AM
AC or AC/DC for Welding Shay 5 fan Welding Shop 8 01-18-2012 02:23:13 PM
Welding rod Chris J Welding Shop 7 08-17-2008 10:22:53 AM
Thoughts on crankshaft welding/ engine block welding Mac Leod Small Air Cooled Gasoline Engines 10 04-14-2008 10:46:02 PM
Welding Matt Fretwell Welding Shop 23 10-12-2003 07:35:59 AM
