Welding Shop
SA 200 F-163 Lincoln
this thread has 4 replies and has been viewed 13575 times
Old 07-22-2008, 01:23:51 PM
Arthur
Default SA 200 F-163 Lincoln
Could someone help me with finding the Vintage of 2 Lincoln welders ?
A friend gave me a Lincoln SA 200 F-163 that seems to be good enough to get it going again. I found another one for parts only that is exactly like the first one except the serial no.
This is the one I want to restore.
Model SA 200 F-163
Mean output 200 Amperes Code - 6633
40 Volts Serial , A-626846
60 % duty cycle
1550 RPM no load
The serial no. on the parts SA 200 is, A-628743
I would like to know what year both welders were made, because I have been told that some of the windings were changed to Aluminum and were not as good. Thank you for any help with this, Arthur
Old 07-22-2008, 09:32:33 PM
ramsay ramsay is offline
Talking Re: SA 200 F-163 Lincoln
Hello: I think the aluminum came in about 1972.. code 6633 ser A613802 was made in 1968.. yours should still be before the change.. mike
Old 07-23-2008, 11:44:05 AM
Arthur
Default Re: SA 200 F-163 Lincoln
Thank you Sir, I do appreciate your response and good information.
I also owe Lincoln an apology, The aluminum might not be able to stand abuse as good as copper. There are many ways to abuse a welder, I have always liked the SA 200 ,having used them for many yrs. Maybe this one will help me recapture my youth. Arthur
Old 07-24-2008, 11:12:30 PM
You are very welcome.. I am in the process of fixing up an old shield arc sa 200 f 162 from 1957.. I use to have to hand crank one like this and weld ten or twelve hours a day with it..Just something to do to keep me busy during retirement.. Mike
The Following User Says Thank You to ramsay For This Post:
Old 07-25-2008, 10:13:38 PM
Arthur
Hello Mike, I am in the same situation, just gota have something to play with or as an old lady said ( to keep me occupated ).
I have been busy for several months trying to bring a Georgie Mud Buggy back to life, boy what a job. I took my first ride this week, you wouldn't believe the patience and work it took for that little ride. It is a tool for hauling wet concrete in small places. I want to use it as a yard machine for hauling and dumping and general lawn upkeep. It is hydraulic drive and dump and so far I'm happy with how it performs.
I'm probably older than you ,but I'm still going strong even though I had surgery about 7 week ago. Thanks again and take care. Arthur
Need help with Lincoln DC-225/3-AS Uncle Willie Welding Shop 1 04-26-2009 07:50:55 AM
Lincoln SAE 300 RandyCldwll Welding Shop 1 12-07-2005 02:08:41 AM
Old Lincoln Ben Bennett Generators & Electric Motors General Discussion 0 09-28-2005 08:09:39 PM
lincoln help Todd Alexander Generators & Electric Motors General Discussion 1 04-12-2004 10:51:22 PM
Lincoln Elk Mike Inglis Antique Engine Archives 1 09-10-2002 04:48:53 PM
