Welding Shop
Separating engine from welding generator
this thread has 8 replies and has been viewed 19347 times
Old 10-26-2008, 12:10:38 PM
Howard H Howard H is offline
Default Separating engine from welding generator
Hi everone ,Even though I'm do mechanic work I've Never split a welder before. I have a Lincoln SA 200-F163 ,1969 model that I have to put the rear seal in and I need help on how to seperate the engine from the welder. I've been to other forums and did searches but can't find any thing.I guess typing it in wrong. I have the overhaul manual for the continental engine, and the diagram of the generator I can't find material on how to split them. Do they have dowel pins or a taper on the shaft? I've wigglied the engine around to see what would happen, but didn't pry to hard to break anything. So I'm asking the professionals to help this newbie into welding for help I thank yall for any and all advise
Old 10-26-2008, 05:16:09 PM
gene w gene w is offline
Default Re: Separating engine from welding generator
not saying this is the answer! but maybe if you are able to drop the pan and the rear main, on some engines it is possible to slip/pull in a new seal
Old 10-26-2008, 05:50:14 PM
Thanks for answering Gene, but I've done that thinking the same thing,But being a rope seal I,ve always pulled the crank to install because of the need to press the rope into the groove. I know of some older chevys with half seals that you can slip in that way.
Old 10-26-2008, 09:08:29 PM
Rodrigue Caron Rodrigue Caron is offline
Howard
There is a special tool to install these seals; just remove the bearing cap. You will find that tool at auto part store.
If you want remove the welder assembly from the engine, disconect battery ground wire. If a magneto is used , remove spark plugs wires on spark plugs ; Look throught generator air outlet grid, you shall see bolts fixing a steel flexing disc to the flywheel. If so, lift exiter and generator brushes, cut three ribs of air grid and remove screws turning engine at each bolt. Use proper lifting device. Remove stator bolts to engine. Back off welder assembly just enough to permit installation of wires in two disc bolts holes and stator frame. Remove welder assembly, That's done,
Take time
Rodrigue
Old 10-26-2008, 09:25:03 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
or drop it in the middle with a nice big wedge. THat the quick way. Note: not responisible for the smallest chance that it could get wrecked.
Old 10-27-2008, 01:47:00 AM
Dempster Dempster is offline
Most auto parts stores will have or can get a Lisle sneaky pete seal tool and otctools dot com may have a tool also.
http://www.lislecorp.com/tool_detail.cfm?detail=383
http://www.sjdiscounttools.com/lis27000.html
Even if you do have to later split it shouldn't have to be cutting fins out of housing. This link shows a guy recently splitting one along with some pics.
http://www.aws.org/cgi-bin/mwf/topic_show.pl?tid=18444
Old 10-27-2008, 01:09:29 PM
Rick McKay Rick McKay is offline
I changed the rear main on my old lincoln 200 about 10-12 yrs ago, and didn't use the "special tool", nor did I separate the generator fromt the engine. After removing the oil pan, I loosened the mains enough to drop the crank about 1/4 inch at the rear and wiggled the rope around into place. After retorquing the mains I trimmed the excess off with a razor blade. the bottom half was a little easier!!
The welder should come apart fairly easily from the engine after removing the bolts. If it's not buried in the iron pile too deep, I might be able to take a picture of one that is out. I fried an armature a few years back and swapped the flywheel and generator for a later one. I also was able to update to electric start. Nice option.
Rick
Old 10-27-2008, 07:47:26 PM
I finally got it done. thank you guys for all the help. It was easier than I thought it was going to be. I should of had my glasses on and better lighting I might have seen the retainer holding the rope seal Thanks agin guys for the info.
Old 12-13-2008, 12:37:10 AM
David Boothby David Boothby is offline
Smile Re: Separating engine from welding generator
if it is a 1969. lincoln welder. contact lincoln electric companyelectriccleveland ohio. that is where they were made. this is there world head quarters. give them the model number. and what size contenental engine it is. and they should have a archieve there that can help you with your welder.
WWll welding generator? Ben Clarke Military MEP and Aircraft Gen-Sets 7 05-15-2008 09:02:06 AM
WWll welding generator? Ben Clarke Military MEP and Aircraft Gen-Sets 0 05-09-2008 09:19:28 AM
Thoughts on crankshaft welding/ engine block welding Mac Leod Small Air Cooled Gasoline Engines 10 04-14-2008 10:46:02 PM
Separating gen head from Kohler L 600 DavesWaves Kohler Generators 1 11-15-2007 10:21:19 PM
Separating engine from Genhead on NH Commercial 6500 GlennB Onan Generators 3 03-31-2007 01:25:31 PM
