Welding Shop
Upgrade my SA 200 alternator
this thread has 10 replies and has been viewed 13811 times
Old 11-30-2008, 07:02:27 AM
mr welder mr welder is offline
Default Upgrade my SA 200 alternator
hello there I want to replace my external regulated factory alternator on my 1980 lincoln sa 200 to a delco remy 130 amp internal regulated alternator can anyone tell me how to wire it ????I would also like to add an ac inverter. has anyone done that??? will try to get some pics on later.
Old 11-30-2008, 03:29:31 PM
David C David C is offline
Default Re: Upgrade my SA 200 alternator
What does the plug for the internal regulator look like. If it is a mid 90's and up, the best thing to do is get the long Delco number off of the alternator (if it is not a rebuilt unit) and I can look up how that particular unit is wired. GM used several different regulators that look alike but they are not wired the same.
I used a Honda 5 hp to spin a 105 amp GM alternator to run a 1000 watt inverter for the first 10 hours of Hurricane Ike. It worked great to power up a couple of lights, computer and the TV.
David C.
The Following User Says Thank You to David C For This Post:
Old 12-01-2008, 08:50:16 AM
hi david it is a delco remy 22si alternator I just dont want to hurt anything when I do the wiring to new alternator these 130 amp alternators are brand new I have 3 of them !!!!!! thanks for your help!!!
Old 12-01-2008, 10:59:45 PM
Some of the 22SI Delco's were self-energizing if I remember correctly. You may have to manually accelerate the engine above the governor setting to get it to start charging. If it is self-energizing, you will only need to upgrade the output wire going to the battery and disconnect the input wire to the old external regulator. I would upgrade to 6 gauge wire to keep the voltage drop within reason when you load the inverter.
David C.
Old 12-02-2008, 06:26:40 PM
Dempster Dempster is offline
Some good advice on Mad Electrical site tech section. There are pros and cons to using 1 or 3 wire alternator depending on what accessories you want to run off it.
http://www.madelectrical.com/electrical-tech.shtml
Couple more places to look or ask:
http://www.aws.org/cgi-bin/mwf/board_show.pl?bid=44
http://www.billswelderrepair.com/
http://www.weldmart.com/
The Following User Says Thank You to Dempster For This Post:
Old 12-02-2008, 07:47:07 PM
thanks for the replies here is what I have and the alternator I want to install!
ID:	44330   Click image for larger version
ID:	44331   Click image for larger version
ID:	44332   Click image for larger version
Old 12-03-2008, 10:13:47 PM
Can you post the 7 or 8 digit number that is on the alternator. I should be able to look it up in some catalogs that I still have from when I used to rebuild alternators. I didn't see many of the 22SI as I did almost 100% passenger car and light truck alternators.
You will also have to bypass the original ammeter or upgrade to a higher amperage ammeter that uses a shunt.
David C.
Old 12-06-2008, 09:52:30 AM
hello david the numbers are 19020801 under that is mx05b04R 1 its a 12v 130A N delco 22si thanks for any help in cross referencing wires you can do for meIM worried bout drive belt issues this alternator came off a 600hp detroit diesel!maybe I should go with a smaller alt. what do you think????
Old 12-06-2008, 11:04:16 AM
I don't know what size inverter you plan on using, but if it is in the 1000 watt range, I would use a smaller case alternator such as a Delco CS130 series. It would make the installation a lot easier. Millions of them were made and are readily available at any salvage yard or parts store.
The pulley selection is a lot better for the CS-130, wich uses the standard 17mm shaft, which is the size that most domestic auto makers have used for the last 40 years. I believe the 22SI may use a taper lock system on the pulley or it at least has a shaft larger in diameter than 17mm, which would limit the selection of pulleys.
The water pump bearings may not like the amount of tension on the belt that will be require to keep the belt from slipping. Most of the industrial equipment now uses a serpentine belt or two belts to handle the load.
David C.
Old 12-06-2008, 01:15:39 PM
thanks david I would like to run a porta band saw would 1000 watt inverter be enough maybe 1/2 inch electric drill???
The Following User Says Thank You to mr welder For This Post:
Old 12-10-2008, 10:16:59 PM
You need to take a look at the amperage rating on the drill and the band saw you will be using. I have personally run a Milwaukee band saw with a 1000w Vanner inverter hooked up to a '85 Ford PU with the 6.9 diesel. I made one cut on a 4" sch.40 pipe, but I did not put a volt or amp meter on it to see what it did with the load. I bought a 40 foot stick at an auction and it wouldn't fit too well on the 16' trailer I was pulling. It would be best to find out what loads you will have and then find a inverter with enough capacity to start and run the load. Will you be using the tools for extended periods? The stock alternator and battery may handle the load, if they are infrequent.
David C.
Regulator upgrade for 15.0RDJC Dan R Onan Generators 3 04-27-2009 05:22:22 PM
Smokstak Software Upgrade Harry Hit & Miss Gas Engine Discussion 3 05-21-2008 09:37:12 PM
To upgrade points or not rusty sloniger Onan Generators 0 03-22-2006 07:45:27 PM
Web Server Upgrade Harry Hit & Miss Gas Engine Discussion 4 11-19-2005 08:16:57 PM
Web Server Upgrade Harry Antique Engine Archives 8 01-06-2002 12:47:56 AM
