Welding Shop
Lincoln Short Hood
this thread has 10 replies and has been viewed 14795 times
Old 01-10-2009, 11:10:14 PM
sparksandslag sparksandslag is offline
Default Lincoln Short Hood
You fellas got me some good help with my carb problem---maybe someone can straighten me out on some sheetmetal. I am looking to find a set of doors to fit my SA200 w/F163 engine, 1967 model, and I see the term "short hood" mentioned. Just what exactly is the difference between a "short hood" and a "long hood", dimension-wise. The hood on my machine measures (I think) 53" long.
Any wisdom someone out there can share will be appreciated.
Old 01-11-2009, 07:53:58 AM
Stu Stu is offline
Default Re: Lincoln Short Hood
If Im not mistaken,,,Its OLD, and the engine is covered and the generator is all sticking out of the rest... Ive seen a few die hard welders with short hoods on the line,
Old 01-11-2009, 11:54:55 PM
Thanks, Stu, that explains it. Mine would be the "long hood" cause everything from one end to the other is covered by the hood.
Old 01-15-2009, 06:57:58 PM
Dempster Dempster is offline
Did you find any doors? I've seen used ones in ads on the AWS forum and others post about new reproduction hoods, doors and covers from a shop in Oklahoma and stainless ones from Corpus Christi Texas. Some are even fancy custom ones with louvers punched out.
http://www.aws.org/cgi-bin/mwf/forum_show.pl
Old 03-16-2009, 05:25:53 PM
OBrien OBrien is offline
The short hood refers to the hood that does not extend over the face of the welder, where as the long hood has a hood that extends beyond the face of the welder.
Old 03-17-2009, 08:23:54 AM
Nitesky Nitesky is offline
NOT - The explanation in the previous post is correct.
Old 03-19-2009, 12:48:56 PM
Here is some pictures to show you the difference between some of the models.
ID:	50673   Click image for larger version
ID:	50674   Click image for larger version
Name:	Redface blackface.jpg
Old 03-20-2009, 05:34:24 PM
Thanks for posting the pics. Your middle pic is a short hood the generator is not all covered. The ones in pic on right are long hoods. Has nothing to do with the instrument face area.
Old 03-23-2009, 09:04:48 AM
pic #1 - shorthood
pic #2 - ? Is that a stock hood?
pic #3 - all longhoods
Old 03-24-2009, 12:51:32 PM
Yes #2 is another short hood. Not sure what years they made them with hoods like that. Many have had hoods changed and can get new reproduction sheet metal for them too. For parts and sheet metal there has been many places listed for those on the AWS forum too where there is a column dedicated to the Lincoln 200s.
Old 05-13-2009, 04:15:47 PM
mcondit mcondit is offline
plenty of brand new carbs on Ebay for these welders. about $200.00 The short hoods were made until 1958.
Locomotive hood ornament? B Kedrowski Steam Stationary Engines, Traction Engines 7 04-25-2009 04:07:23 PM
New Welding Hood Holland501 Welding Shop 14 08-31-2008 03:12:52 PM
Owl hood ornament? Tom Winland Antique Autos and Trucks 8 06-17-2008 07:16:21 PM
Ford hood Sky Antique Autos and Trucks 8 04-13-2008 10:01:22 AM
Cat-426 hood opening Backfire Antique Farm Tractors 0 03-15-2008 11:18:18 PM
