Smokstak Down Under
Mcdonald Imperial "Super Diesel"
this thread has 67 replies and has been viewed 13699 times
Old 11-25-2009, 07:48:36 AM
E27N's Avatar
E27N E27N is offline
Default Mcdonald Imperial "Super Diesel"
Found this little gem on my travels as a Case IH field service tech
Name:	25112009123 (Medium).jpg
Name:	25112009124 (Medium).jpg
Name:	25112009125 (Medium).jpg
serial no reads 44110E
It says crude oil on the wall side i presume this means it runs on crude oil though it doesn't appear to have a hot bulb I dunno i'm no expert on Mcdonalds, It is free and has good compression I hope to pick it up on Saturday, can anyone give an age, Hp(4-5 I would guess) rpm etc or some where I can find out
Cheers Andrew
Old 11-25-2009, 08:53:01 AM
oldgoat oldgoat is offline
Email NOT Working
Default Re: Mcdonald imperial "super diesel"
Looks like a C.E. McDonald built mid 30's tp 1950 about 4.5 hp at about 450 rpm. Starts easily and runs well on diesel fuel
The Following User Says Thank You to oldgoat For This Post:
Old 11-25-2009, 08:55:27 AM
Ray Freeman Ray Freeman is offline
Serial numbers in 1934 run from 4433 to 4468.Should be an FF type.5 HP at 500 rpm. 5 inch bore and 7 inch stroke.Got no info on the E after the number. Could it be F? That would mean rebuilt by factory. This series of engine run from 1919 to 1951. They were a larger version of the C type.
This is all straight out of the McDonald book Ďndustrial Pioneer"
The Following User Says Thank You to Ray Freeman For This Post:
Old 11-25-2009, 10:15:15 AM
E27N's Avatar
Thanks guys, looking at the photo's now with a bit of knowledge is it possible that it actually reads "4411CE" not 44110E which I presume makes it a CE type as Oldgoat stated.
Cheers Andrew
Old 11-28-2009, 07:16:28 AM
E27N's Avatar
Well It's finally home, After a wash I can confirm the serial no being 4411CE the insides look good, the injector assy is stiff but OK I think i doused it with penetrating oil before i knocked off Does anyone have a manual i could copy or know where to source one(haven't looked at ploughbooksales yet) as I would like to know starting procedures, what oil to use ETC
Cheers Andrew
ahhh just noticed this is my 100th post yay me!
Old 11-28-2009, 11:51:03 PM
E27N's Avatar
more pics when my pooter behaves
Name:	PIC_0157 (Medium).JPG
Name:	PIC_0158 (Medium).JPG
Old 11-28-2009, 11:59:43 PM
ozfarm ozfarm is offline
u idiot
freeman has spotted and will start devising methods of removing it from your possession
Old 11-29-2009, 12:03:00 AM
E27N's Avatar
He can try but considering this is the crown jewel of my collection he will fail......miserably
Old 11-29-2009, 03:25:50 AM
Don't worry you can keep itI'm Line Boring Ozfarms seeder sometime soon and I'm going to have to borrow your truck to get all the McDonalds he's paying with back to Perth.(can your truck pull doubles?)
Old 11-29-2009, 03:38:47 AM
E27N's Avatar
ahhh the plot thickens......
pooter finally behaving more pics
Name:	PIC_0159 (Medium).JPG
Name:	PIC_0160 (Medium).JPG
Name:	PIC_0161 (Medium).JPG
Name:	PIC_0162 (Medium).JPG
Old 11-29-2009, 09:46:21 AM
E27N's Avatar
IT LIVES! took some coaxing and the help of an upturned Jim Beam can with the base full of flaming metho but it goes gave up when i lost sight of the back wall of the shed for all the smoke I do have one question is it a hit and miss or is it just misfiring ?? need to build a base for it and take it out side and give it a good run but thats next weekend......
Old 11-29-2009, 10:10:57 AM
It runsDo you need any on site line boring done?
Old 11-29-2009, 06:27:30 PM
E27N's Avatar
AAAAANNNNNNDDDD ozfarm was right........
Old 11-29-2009, 06:36:09 PM
He's never been "right "since he fell out of the tractor cab onto his head from a great height.
Old 11-30-2009, 02:15:39 AM
see, told u not to post a piccy of it
know "cousin it" has seen it , it will become a matter of honour for him to try and remove it from your posession by methods most ungentlemanly
freeman better hope i havent got the mower deck on the cub cadet when he rolls up here,
Old 11-30-2009, 07:40:26 AM
E27N's Avatar
Default Re: Mcdonald imperial "super Diesel"
hehehehehe wanting to pull the piston this weekend to hone the bore, lap valves check rings etc so can any one give me the head bolt and big end torque specs????
cheers andrew
Old 11-30-2009, 10:47:15 AM
Had a look at a McDonald handbook tonight. No such thing. Just tighten em up. But if you think you might twist them off drop the engine here and I'll make sure its looked after
It could join the SE (1944) I picked up this arvo Not a goer yet but its all there. Just got to make sure all the brons stuff is hooked up right.
Old 11-30-2009, 10:49:45 AM
Hey,and it came with a spare manual too
Old 12-01-2009, 08:02:48 AM
E27N's Avatar
no it's comfortable with it's mates the SL1 lister,XD sunbeam, PH1 petters and kohler light plant it' likes their company
Old 12-01-2009, 09:36:50 AM
You want the manual or not?Its for a CE as well as the SE. Got all the how to run and tappet settings etc.
McDonald Imperial Super Diesel Phil Elshaw Vintage Diesel and Oil Stationary Engines 28 02-10-2014 07:58:07 AM
A.H.McDonald Imperial Super-Diesel Bryan Hearps Vintage Diesel and Oil Stationary Engines 8 07-20-2012 07:43:56 PM
McDonald HVID Diesel Engine alext Hit & Miss Gas Engine Discussion 0 12-24-2008 11:57:26 AM
Imperial diesel info?? Kirk Taylor Antique Engine Archives 5 10-31-2003 07:05:15 PM
A.H.McDonald Super diesal Gary Stanway Antique Engine Archives 0 09-30-1999 10:07:04 AM
