Need Info on 1945 Fairmont Speeder Motor
this thread has 9 replies and has been viewed 3050 times
Old 03-19-2010, 05:00:37 AM
Danf Danf is offline
Question Need Info on 1945 Fairmont Speeder Motor
I have a 1945 Fairmont railroad speeder motor (determined from an online website), that I was sure was a R.O.B. I've had someone tell me that it looks like an RQ with a C-8 carb. Numbers I've gotten off of it are 69524 - from below the radiator, A 1045 - on the block, E 6995 - from the generator, Fairmont TYPE 08 and A 1319 - from the carb, and A 1372 from the wheels. It is missing it's gas tank, it isn't currently a running engine, I have had it running a few times before, still has very good compression. I don't believe it would take much to get it in top shape again. I haven't been successful in finding info on the web so thought I'd try here. Also would like to know it's actual value. I've attached a couple of photos. Thanks in advance for any help.
Name:	front 1 use.jpg
ID:	75719Click image for larger version
Name:	back 2 definitely.jpg
Name:	left side use.jpg
ID:	75721Click image for larger version
Name:	right side use.jpg
Old 03-19-2010, 06:56:22 AM
garryb garryb is offline
Default Re: Need Info on 1945 Fairmont Speeder Motor
http://motorcar.winkworth.us/engines..._index.htm-Try this link.
Old 03-19-2010, 07:18:59 AM
lowboy
most of the motor cars had the tank attatched to the "cars" frame up near the back I just rigged a small round tank on a bracket near the carb
Old 03-19-2010, 07:40:20 PM
Dirk Jr Dirk Jr is offline
It is a Fairmont RQD 9-13 HP
Old 03-20-2010, 04:08:14 AM
Dirk, can you give me some insight as to how you determine this? So far, from what I have found, the serial # for my engine puts it as being manufactured in February 1945, but that's about all I've found out. This came from two different websites, one mentioned by a member here earlier.
Old 03-21-2010, 08:43:54 PM
The RQD is easy to spot from their little cousin, the ROB. The condenser is a give away for this engine. Only the large Fairmont engines and the RK twin use the large condenser.
Old 03-24-2010, 08:18:18 PM
Cool Re: Need Info on 1945 Fairmont Speeder Motor
Hi Dirk, I'm believe that my engine is 6 hp. Can you give me an idea where, other than the website already mentioned on this thread, I can find out more information on RQD's, ROB's etc.? Thanks, Dan
Old 03-24-2010, 09:02:18 PM
Your engine is the big guy 9-13 HP.
You can poke around this site for info. www.narcoa.org
Old 03-28-2010, 11:27:46 AM
wsrutherford wsrutherford is offline
Dirk is right. You can check some of your part #'s @
http://www.brownrr.com/catalog/index.php
Your water jacket # 69524 is FMT 69524.
Brown can be a little high $ wise
Old 03-28-2010, 06:59:09 PM
Mr Brown's prices go down as you get to know him.
Fairmont Speeder Engine OldironPhil Hit & Miss Gas Engine Discussion 14 11-10-2009 09:21:41 PM
RR Speeder Engine Doug Kimball Unidentified Engines 4 04-30-2009 09:15:48 PM
Help with info on this Fairmont engine shanelc50 Hit & Miss Gas Engine Discussion 15 02-19-2009 05:58:38 PM
Fairmont Motor jody smith Antique Engine Archives 3 10-03-2001 10:51:45 PM
fairmont railroad motor car engine John Landrum Antique Engine Archives 1 10-11-1999 07:52:48 PM
