Welding Shop
Old Presto Lite Torch
this thread has 23 replies and has been viewed 26185 times
Old 05-07-2010, 03:40:19 PM
PTSideshow PTSideshow is offline
Default Re: Old Presto Lite Torch
Never claimed I could spell
The Following User Says Thank You to PTSideshow For This Post:
Old 05-08-2010, 04:11:42 PM
petesoldsaw petesoldsaw is offline
Default Re: Old Presto Lite Torch-KidDynamo
Hello John
Thanks so much for the Prest o Lite torch manual!Your the man! I will try and have your money in the mail on Monday of next week.The information got here real fast,the customs must not have been that busy, LOL!
I have a couple of questions but will ask them later today as I have a few things going on right now.One I will post up in the small engine forum or whereever you would post a problem for a lawnmower problem.Many Thanks
Lawrence
Old 05-17-2010, 11:00:00 PM
Lloyd H Lloyd H is offline
MC = motor cycle B = bus most cars used the B tanks however. Started in the HVAC trade in high school with an old man that used a B tank with no regulator and a torch handle like the one in the first post. He had used it for years, only bad thing was tricky to adjust with the tank valve. My first B tank setup had an aluminum regulator as pictured by KidDynamo in post 16 third picture except no needle valve. used it since 1967 and scrapped it about three weeks ago with a leaky diaphragm. The "Turbo" tips are worth the extra money, they save enough acetylene to pay for them selves if silver soldering, fittings come to silver solder temps in half the time. Lloyd H
Old 07-07-2013, 01:38:26 PM
chucketn chucketn is offline
I know this is an old thread but I'm hoping to find a Prest-O-Lite expert here... I have just rebuilt a Prest-O-Lite 401 torch, replacing the leaking, dried out o-rings. Is anyone here familiar with setting the shutoff valve after changing the 0-rings? I screwed the valve body in until it seated and the pilot valve works but the main shutoff has no effect.
If anyone has a Prest-O-Lite 401 torch that they use, would you mind taking off the outer part of the shutoff valve and counting the turns from the off position to the valve seat, Please? I would be so greatfull!
BTW, I got the proper o-rings from weldingsupply.com, usual disclaimer...
Chuck
Engine Torch Duane H Hit & Miss Gas Engine Discussion 5 08-07-2013 04:03:36 PM
Some kind of Torch Christian Berlin Farm Antiques and Collectibles 8 04-06-2009 05:24:52 PM
Need help with acetylene torch Ronald E. McClellan Welding Shop 9 03-16-2007 09:13:17 PM
Help me before I get the TORCH! Norm S Antique Engine Archives 8 02-17-2002 09:21:42 PM
Litscher Lite Glenn Karch Generators & Electric Motors General Discussion 1 11-08-2000 06:59:47 AM
