Welding Shop
Hobart vs Miller Welder Generators
this thread has 9 replies and has been viewed 14728 times
Old 01-15-2011, 05:46:41 PM
Holland501 Holland501 is offline
Default Hobart vs Miller Welder Generators
Hi Guys,
I'm in the market for a large welder/generator. I think I've narrowed my choces down to either the Hobart Champion Elite or the Miller Bobcat 225. They look to be the same machine as far as specs go. Also, if I'm not mistaken, doesn't Miller own Hobart, or something like that? The machines are virtually the same as far as features and price, unless there is something I'm missing. Does anyone have any input on these. I know down the road if I ever want to sell, I'll probably get more for the Miller but that's way down my list for choosing one over the other.
All opinions welcome.
Thanks for Taking the Time
Old 01-15-2011, 07:34:29 PM
Dave Wight Dave Wight is offline
Default Re: HOBART-vs-MILLER
501 if these welders are both stick machines chose the hobart, if they are hardwire then chose the miller. hope you have the best of luck. dave
The Following User Says Thank You to Dave Wight For This Post:
Old 01-15-2011, 07:41:19 PM
fordmustang1984 fordmustang1984 is offline
I would go with the Miller, i saw one in a welding supply store and it was a pretty rugged looking machine. And i like the fact that it does all processes.
The Following User Says Thank You to fordmustang1984 For This Post:
Old 01-15-2011, 08:16:13 PM
Farmer John Farmer John is offline
i have one of the champions i like it ....i believe they are the same just depends if you like blue or off white.....
The Following User Says Thank You to Farmer John For This Post:
Old 01-16-2011, 07:29:23 AM
PTSideshow PTSideshow is offline
As you have said Hobart is owned by Miller, it is generally a home/farm hobbyist/shop machine. Here is the link to the Miller board there generally is at least one thread running on the Bobcat 225
Here is the Hobart forum they have all the product info on both and the info good or bad is posted
Tractor supply has the Hobart brand and they do put them on sale.
The Following 2 Users Say Thank You to PTSideshow For This Post:
Old 01-16-2011, 02:01:03 PM
i bought mine at a welding supply shop where i have a buddy working it was on sale too still not cheap....john
Old 01-16-2011, 02:37:31 PM
ar2stp48 ar2stp48 is offline
If the difference in purchase price is within budget, go with the Miller. Hobart is owned by Miller and is usually considered a lower level Miller. You will be better satisfied with the Miller.
The Following User Says Thank You to ar2stp48 For This Post:
Old 04-25-2011, 11:59:41 PM
The motor kid pig guy The motor kid pig guy is offline
The miller is more for for the commercial use heavy duty the hobart
Is more for home light duty there both good but millers have been around and u know the durribality
The Following User Says Thank You to The motor kid pig guy For This Post:
Old 04-26-2011, 09:27:13 AM
mrxlh mrxlh is offline
The Hobart is actually a better welder than the Miller for the money. The Champion 10000 is a straight DC welder with 1 knob to twist, therefore it is a little less costly, and less to break or go wrong. They both have an identicle warranty and use the exact same engine.
The Champion Elite and Bobcat 225 are the same machine as well, so if I couldn't find a Champion 10000, I would suggest which ever one is cheaper, again, same engine, same rotor, same warranty.
The Following User Says Thank You to mrxlh For This Post:
Old 08-06-2011, 02:55:29 PM
wlbrown
Default Re: Hobart vs Miller Welder Generators
HELLO,
suggest you go up one step, and get the bobcat
250 miller. this is what i have, and it has more
features than the 225 bobcat. also try to get one
with the kohler engine.
wlbrown
Miller welder/generator help please. envelopes2007 Welding Shop 4 03-24-2010 02:39:32 PM
Miller Roughneck 2E Welder teppler Welding Shop 2 02-08-2010 07:33:18 PM
Old Miller welder model 61 p knightsun Welding Shop 2 09-17-2009 11:37:03 AM
Miller Welder mig gun holder. aametalmaster Welding Shop 5 07-10-2009 10:16:01 AM
miller welder sparkplug54 Welding Shop 0 12-03-2006 06:24:02 PM
