Welding Shop
Lincoln SA200 welder generator, no output?
this thread has 9 replies and has been viewed 13544 times
Old 03-15-2011, 07:53:49 AM
Arkie Arkie is offline
Default Lincoln SA200 welder generator, no output?
I posted this in the welder /gen section and no response!
Can anyone give me some troubleshooting hints for checking a Lincoln SA-22-F163 Engine driven welder that has no weld output?
Im also looking for a service manual or service data electrical schematics that are no longer available from Lincoln! I have a owners manual!
Any help appreciated! I have all kinds of electrical testers, but not familiar with this type gen/welder and need few hints for testing?
I posted in the welder /gen section yesterday and no replys![COLOR="Silver"]
[QUOTE=Arkie;622973]I posted this in the welder /gen section and no response!
Old 03-15-2011, 08:14:29 AM
K D Redd K D Redd is offline
Default Re: Lincoln SA200 welder generator, no output?
Have you tried Lincoln website?
Kent
Old 03-15-2011, 08:32:27 AM
John in Maryland's Avatar
John in Maryland John in Maryland is offline
They still have manuals for obsolete welders. http://www.lincolnelectric.com/en-us...r-manuals.aspx
I have a Lincoln G8000 that lost weld and aux power output. I found a bad connector on one of the rectifiers. If the manual(s) don't help, check all electrical connections, brushes, switches, everything you can see and or get to.
Good luck.
J.I.M.
Old 03-15-2011, 02:09:28 PM
Appears I need a M8781 connection wiring diagram per your link, which is no longer available! Anyone have one to share? (I have the owners manual)
I do not have any DC voltage at the receptacle (120vDC receptacle) which I suspect is also the exciter voltage, which I must have to produce the welding current output?
Old 03-15-2011, 06:33:22 PM
Did a Google search, found this: http://billswelderrepair.com/SA200schematics.html
and this: http://www.weldmart.com/technical/EX...BLSHOOTING.htm
Old 03-15-2011, 07:12:22 PM
Heins Heins is offline
I bought an engine driven DC welder one time and it wouldn't weld until I took a copper wire and touched both terminals where the welding leads bolt on and then it took off and welded.
Old 03-15-2011, 08:01:49 PM
KEB KEB is offline
If its sat for a while, try cleaning the commutator in the welder. Doesn't take much corrosion to make a bad contact on the low voltage, high curent windings. Buff with scotchbrite until shiny. Don't use sandpaper as it can leave abrasive particles in the commutator.
Keith
Old 03-15-2011, 09:10:04 PM
Originally Posted by John in Maryland View Post
It appears the link tto weldmart is the info We need to start the testing!
Thanks and I'll be back later!
Old 03-22-2011, 07:53:22 AM
exciter coils are tesing ok and phased correctly using ohmmeter per owner!
I told him to remove the armature and do a visual and take it too motor shope for growler testing!
He called back and said insulator pieces on opposite end from communtator were missing and some were coming out of the Armature!
Armature sounds sick and weak and needs attention!
Old 03-24-2011, 08:43:48 PM
SA-200 is welding!
Be-Aware that this is a un-safe procedure and not recommended by me for all because the automotive group 24 battery can explode. His battery was located approx 20 ft away behind some plywood, etc in case of explosion!
A guy told him to connect a isolated (isolated means not connected to anything else) 12v battery of proper polarity, neg to left brush and pos to right brush lead with jumper cables while the motor is running at proper rpm of approx 1550 and have a DC voltmeter connected to the same point as the brushs and keep a heads up for the brushes to eventually (may take 1-3 minuites) start arcing and at same the voltmeter voltage starts rising and when it get to approx 15 to17 volts unhook the battery and see if the voltage keeps building to the 115vDC. If the voltage decays or drops connect the 12v battery again! He said to keep a heads up when the voltage starts building (getting above the battery volts) and the brushes arcing because the generator exciter is genning back into the 12v battery and to not connect at disconnect at the battery due to possible Hydrogen gas explosion! (the battery is charging and discharging at a high rate)
He said when the gen ran about 2 min and the brushes started arcing and the DC voltage came up to about 17 down to 12 and was unstable and finally the voltage stayed at 17 and the brushes stopped arcing and the DC came to 115 when he un-hooked the battery and he connected a 8 amp grinder to the receptacle and it ran good and tested a weld arc as ok!
The unit had been sitting un-used for about 6 mo's and had two problems, rat chewed wires and loss of pole pieces residual magnetism! Main problem was loss of residual magnetism! When he killed the engine and re-started several times it's re-excited it-self, so the iron core pole pieces are holding residual magnestism for now!
Thanks to all and Dempster for the good helpful info!
Lincoln welder, engine driven, no output? Arkie Welding Shop 14 03-25-2011 06:39:02 AM
Lincoln SA200 Welder clintonmetalcraftsman Welding Shop 4 08-13-2010 09:25:38 AM
Antique Lincoln Welder / Generator Tom Schoolcraft Generators & Electric Motors General Discussion 8 08-30-2007 05:19:23 PM
Lincoln Welder/Generator Jim H. Welding Shop 5 12-14-2005 09:56:59 PM
Lincoln generator/welder NOT KOHLER!!! Shop7 Kohler Generators 0 11-17-2002 12:54:34 AM
