Welding Shop
Lincoln SA200 running like poo
this thread has 6 replies and has been viewed 13346 times
Old 05-24-2011, 06:16:19 PM
dtscott dtscott is offline
Default Lincoln SA200 running like poo
I am rebuilding a 58 sa 200 i put in new plugs and wires. also rebuilt carb it runs but sound like it missing(sounds like an old john deere). So i but a new cap, rotor, points, and a condenser in the mag still the same. any ideas?
Old 05-24-2011, 06:42:03 PM
Dempster Dempster is offline
Default Re: sa 200 running like poo
Smoking running rich ? Carb won't adjust ? Carb leaking fuel running over ? Check the float for leaks or replace it new. Cleaned the carburetor out ? Fresh gas ? Clean tank ?
Timing correct and timing order correct ? Getting enough air or is air cleaner all plugged up ? Try with air cleaner disconnected.
Name:	SA200 Firing Order.jpg
Old 05-24-2011, 08:00:47 PM
Windables Windables is offline
check firing order and check for stuck valves i got one too 4 cyl lincoln
Old 05-25-2011, 12:22:13 AM
Heinrich Heinrich is offline
Check the firing order and the way the magneto rotates.
I believe it rotates clockwise as you are viewing it from the cap.
bills welder repair in Oklahoma has a lot of good links for troubleshooting and timing that engine.
www.billswelderrepair.com
http://www.billswelderrepair.com/files/IM277.pdf
Old 05-27-2011, 12:28:22 PM
Firing order posted in diagram above. NOTE the Bosch & FM mag #1 position is different and should see a 1 on cap of those & Wico. Get two wires crossed or firing order off it's not going to run right.
Old 08-07-2011, 02:44:05 PM
Oilpulled Oilpulled is online now
I fixed mine. Make sure mag is sparking good. The Marvel Schebeler carb has a small vertical passage in bowl casting which must be open to gasoline in the bowl. Blow in it and the gasoline should bubble. If not, clean out with small drill. I had to get a lot of rust out and then even drill through the brass tube to open the passage. That fixed the idle problem. Idle mixture clockwise increases richness. Read the manual posted on another post in this thread.
Old 09-04-2011, 12:45:13 AM
cub102 cub102 is offline
you probably have 2 plug wires switched. trace them out again and it should be fine
can any of you guys tell me how to post a question on here ? i cannot figure it out
See this: http://www.smokstak.com/forum/showthread.php?t=40589
i have a 1959 Lincoln SA 200 that runs perfect but is very hard to start, once it starts it runs great has good compression valves are perfect a new zenith carb.
it did the same thing with the old carb.
have any of you had this problem ?
thanks
Lincoln SA200 welder generator, no output? Arkie Welding Shop 9 03-24-2011 08:43:48 PM
Lincoln SA200 Welder clintonmetalcraftsman Welding Shop 4 08-13-2010 09:25:38 AM
I cant seem to get complete information on the Lincoln Shield Arc SA200 DC we own. rocketgirlee Welding Shop 2 05-05-2010 06:05:31 PM
sa200 welding red hot mounted fire Welding Shop 2 10-15-2009 11:31:04 PM
Seating brushes in a Lincoln SA200 mr welder Welding Shop 2 02-28-2009 10:13:09 PM
