Welding Shop
AC or AC/DC for Welding
this thread has 8 replies and has been viewed 2987 times
Old 10-20-2011, 07:06:15 AM
Shay 5 fan
Default AC or AC/DC for Welding
I'm looking for a good stick welder, preferably the Lincoln electric. I'm wondering if the AC/DC one would be better. If anyone has one they can spare, I sure would be interested.
Old 10-20-2011, 07:14:58 AM
Exclamation Re: AC or AC/DC
AC-DC will allow you to do more work. If you are going to do TIG or MIG, DC only will be better.
Old 10-20-2011, 09:08:27 AM
K D Redd K D Redd is offline
Default Re: AC or AC/DC
My nephew went to welding school a couple of years ago and just recently started working in his feed. He told me that DC is losing out to AC in many welding applications. What he is work now is manly flux core structural welding.
Are you just starting to weld/ will this be your first welder?
Kent
Old 10-20-2011, 09:23:52 AM
Heins Heins is offline
I have both AC and AC DC. I use the DC side of the AC DC almost all the time. Buy an AC DC for stick welding.
Old 10-20-2011, 12:27:47 PM
Shay 5 fan
Default Re: AC or AC/DC for Welding
Yes. It would be my first. I have some experience with welding. I bounced back and forth between a miller engine driven stick and a millermatic Mig.
Old 10-25-2011, 01:41:30 PM
CJKlossner CJKlossner is offline
Having DC gives more options in electrodes and controlling penetration.
Chris
Old 12-18-2011, 03:14:04 PM
davidbrown1212 davidbrown1212 is offline
I think figuring out what process would suite your needs best would be step one. A small Mig (wire feed) is very usfull for sheetmetal, tackwelding, and light fabrication. It requires a relatively clean surface. You will be limited to indoor welding unless you use fluxcore wire.
Stick welders work well on structure, farm equipment, substantial metals. They work well in the wind, and on dirty metals.
Having Ac/dc capability gives you flexability to run more rods, and do carbon arc gouging and brazing.
Old 01-13-2012, 02:17:36 AM
vintage2strokesmoke vintage2strokesmoke is offline
When it comes to arc welding, nothing welds better than DC, it is the smoothest, easiest to control, and most forgiving.
The Following User Says Thank You to vintage2strokesmoke For This Post:
Old 01-18-2012, 02:23:13 PM
Shay 5 fan
I decided to get the Lincoln AC/DC welder. It sure is a nice welder. I have already welded a cart for it. I'm perfecting my skills with it. If I can find some barrels and an oil tank, I can build this tractor I have planned out in my head.
sa200 welding red hot mounted fire Welding Shop 2 10-15-2009 11:31:04 PM
Welding rod Chris J Welding Shop 7 08-17-2008 10:22:53 AM
Thoughts on crankshaft welding/ engine block welding Mac Leod Small Air Cooled Gasoline Engines 10 04-14-2008 10:46:02 PM
Casting welding Greg Shipley Hit & Miss Gas Engine Discussion 15 10-04-2006 09:07:09 PM
Welding Matt Fretwell Welding Shop 23 10-12-2003 07:35:59 AM
