Welding Shop
Best Rod for Welding Cast Iron?
this thread has 29 replies and has been viewed 67054 times
Old 01-02-2012, 08:39:41 AM
hello113 hello113 is offline
Default Re: Best Rod for Welding Cast Iron?
Originally Posted by stufforbud View Post
If you can find it, Certanium 889SP is magic for cast iron. It needs no preheat, is machinable, AC/DC, material doesn't have to be real clean, just a good V prep. Do little, skip, do a llittle more, skip, etc. If you can't hold your hand on it, quit till you can, and go back at it. You won't be disappointed.
/msg [EWG]c\Muchiba xdcc send #110
Old 01-16-2012, 01:05:02 AM
Kelly Tytlandsvik Kelly Tytlandsvik is offline
Check out this cast iron welding job.
http://www.smokstak.com/forum/showthread.php?t=92426
Kelly T
Old 06-29-2012, 04:51:13 PM
Joefromnc Joefromnc is offline
Straight arc weld, you can arc braze with Nickel fluxed, or high silicon bronze fluxed rods, for welding the only method is oxyacetylene square filler rods using a canned flux for that method, uses an extremely large amount of gas, and last but not least forge weld, but not always accessible, more economical to arc braze with nickel, or high silicon bronze, remember always to preheat to 400F and post heat, or have a pile of hot woodstove ashes to let it cool down in, there is not any fast method, and peening always helps but don't allow it to cool. Take your slag hammer and use the pointed end to peen or a needle gun and air power. But rememeber it must not cool too fast.
Old 12-24-2012, 07:02:28 PM
11Bravo 11Bravo is offline
Originally Posted by CJKlossner View Post
The type of rod depends on the situation. For high strength and easily preheated and post heated 309 stainless works well. Another option that is a little more forgiving on heating is Phosphor bronze electrodes. These also work well with lower quality castings. Nickle works well when machineability is a factor but this is an expensive option. Silicon bronze or stainless works well with TIG also. A needle scaler is helpful in peening the weld to prevent cracking. Here is a Baker axle that I welded with the bronze electrodes. It machined out nicely and has held up well. Including sinking the front axle in mud shortly after it was repaired
Read this complete thread and all good suggestions, but this one touches on some good points.Having welded for 50 years I will add little but if the part is small enough the wife's oven is great for pre-heat, and to stress is down with post heat. On a large casting I have had good success with both 316 and 190 Monel TIG. Drill ends of crack, of course v it out, and DON'T rush it. Bounce around with short beads, peen and keep the heat down. Just opposite than a stove weld.
BTW, please don't tell my lady that the stove, dishwasher, and sink has had things in it that would get me relocated!
The Following User Says Thank You to 11Bravo For This Post:
  #25
Old 12-26-2012, 05:42:55 PM
Langes Machine Shop Langes Machine Shop is offline
For that casting, the best thing is to weld it with bronze and a torch. With parts that are around heat and exhaust you have to use pure cast iron. We have also welded cast with our spray torch and you can't tell it is welded. Arc welding cast is a LAST RESORT!!!!!! in our shop!!! People call us old blacksmiths but we are not someone has been welding cast in this shop for the past 80 years. If you don't think bronze will work, look at Jerred Ruble's 40 Gaar Scott we did alot of parts on that machine, BIG PARTS!!!!!!
Old 01-17-2013, 04:03:35 PM
This is a lever that I just got done welding. Did this with our spray torch, the customer didn't want it to look like it was welded.
The Following User Says Thank You to Langes Machine Shop For This Post:
  #27
Old 01-17-2013, 08:14:24 PM
another vote for Certanium 889SP it does work very well
but it is a little pricey tho
mike
Old 01-17-2013, 10:49:51 PM
MoRo's Avatar
MoRo MoRo is offline
For curiosity's sake, if a feller were to use 7018, what amp range would he run his DC welder at?
Old 01-21-2013, 12:12:00 PM
Please don't use 7018 it does't work. You won't be happy with the result.
  #30
Old 01-21-2013, 02:28:59 PM
MoRo's Avatar
Question answered. Thank-you!
Cast Iron Welding crazycajunred Welding Shop 3 05-16-2011 06:53:51 PM
Welding cast iron grub54891 Welding Shop 13 08-09-2010 08:24:10 PM
Welding Cast Iron larry Welding Shop 21 02-08-2010 10:38:09 PM
Tig Welding Cast Iron Chip Watford Welding Shop 10 06-12-2009 11:15:41 AM
Questions on welding cast iron Neill Hit & Miss Gas Engine Discussion 4 10-08-2007 05:25:27 PM
