Go Back   SmokStak > SmokStak® Vintage Heavy Industrial Equipment > Railroads and Equipment > Railroadiana
Railroadiana Collectibles from the Railroads. Railroadiana or railwayana refers to artifacts of currently or formerly operating railways around the world.
Railroadiana
Railroad Station Tug?
this thread has 9 replies and has been viewed 744 times
Old 11-16-2018, 10:02:06 PM
hd1937 hd1937 is offline
Default Railroad Station Tug?
All,
I acquired this from a family that thought this had been used in a railroad station as a tug or shop mule. After hours of looking around the internet I am unable to find anything similar. Any Ideas? I would really like to find a hitch for it.
Thanks.
ID:	323019   Click image for larger version
ID:	323020   Click image for larger version
The Following 3 Users Say Thank You to hd1937 For This Post:
Old 11-16-2018, 10:34:46 PM
Default Re: Railroad Station Tug?
Sorry I started a second thread.
I've posted on so many sites trying to find information I mistakenly doubled up.
Old 11-16-2018, 11:27:36 PM
I like this. I am glad you posted again. I saw a 3 wheel shop mule at Chapin (the hand pump sprayer people in Batavia NY wasn't identical, but the same idea.
Old 11-17-2018, 09:52:11 AM
Fairmontman Fairmontman is offline
There is a guy here in South Dakota that has a Chicago North Western tug that is a McCormick Deering. It was used to tug baggage carts around the Huron, SD freight house.
The Following User Says Thank You to Fairmontman For This Post:
Old 11-17-2018, 04:11:10 PM
sylvan82 sylvan82 is offline
Not sure what your Tug was used for but this same type of Tug was being used moving all types wheeled material containers in the auto plants in the 1950's.
Just keep in mind that your Tug engine looks like the one that is in my 1928 Model "A" Ford.
sylvan82
The Following 2 Users Say Thank You to sylvan82 For This Post:
Old 11-17-2018, 04:17:02 PM
Glenn Gieszler Glenn Gieszler is offline
I had one here for a while it was an Mercury Industrial tractor or tow tractor I do have the original literature to go with it, they were used quite extensively in all related fields needing to move people or materials in a large plant setting
The Following User Says Thank You to Glenn Gieszler For This Post:
Old 11-17-2018, 08:16:35 PM
Ron Matson Ron Matson is offline
What you have is a Lansing tractor made by the Lansing Company of Lansing, Michigan, ca 1940. They also had a factory in Poughkeepsie, N. Y.
The Following 5 Users Say Thank You to Ron Matson For This Post:
Old 12-17-2018, 12:09:24 AM
Mikechoochoo Mikechoochoo is offline
that surely is a model a engine, they used them a lot in industrial equipment . I worked for a company in the early 1970's that had a forklift they no longer used with an A engine and a ford truck transmission and rear axel that had been narrowed.
Old 12-17-2018, 01:42:09 AM
JoeCB JoeCB is offline
Yep' Sure is a Model A Ford engine, complete with original carb, distributor and all. So if this rig was built in the 1940's what's with the engine? Were they buying and rebuilding old "A" engines ? or somehow finding and using new stock?
Joe B
Old 12-17-2018, 10:29:29 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Just because the model A was no longer in production, doesn't mean that the components weren't still supplied for industrial needs. Also there's the Army surplus stockpile that was being thinned out after the war. Many low volume builders went this route to keep costs low. Massey Harris had to go to the Army Stockpile for motors after the war to keep their tractor line going after a strike at their motor supplier cut off deliveries. Think of the lost sales they would have faced right when the post war farm machinery boom was in full force, if they were forced to stop production.
Canada's First Gas Station casertractor Smokstak Canada 2 05-30-2018 08:40:31 AM
Virginia Railroads - Louisa Railroad, Virginia Central Railroad, Cheaspeake and Ohio Watt Plow Railroadiana 1 03-25-2018 03:42:16 PM
McHenry Minnesota loop Railroad station complete liquidation Glenn Gieszler Live Auctions of Engines, Tractors and Old Iron 1 07-06-2015 11:24:03 AM
Transfer station David Greenwalt Antique Engine Archives 6 04-01-2003 04:19:22 PM
