1944 Continental Motors 300 Watt 12VDC Navy Generator
this thread has 7 replies and has been viewed 2923 times
Old 03-26-2013, 10:30:50 PM
Default 1944 Continental Motors 300 Watt 12VDC Navy Generator
i saved this from going to the scrap yard today. some people..... weighs in at 85 pounds. looks to be complete.. good compression and spark.. was told it sat in a barn locally since the 60s.. engine oil had a red tint to it.. cool exposed valve springs and tiny carb. base gas tank looks really clean.
the tag below the id tag says accepted by navy 6? -44. also it has a start button on top right above the amp gauge.. below the gauge there are numbers L . 4095 serial no 2278 model eag-1 2500 rpm 4 cycle. nothing on the placed in service side.
can anyone tell me what this would of been used for? or any other information?
thanks!
ID:	161376   Click image for larger version
ID:	161377   Click image for larger version
ID:	161378   Click image for larger version
Old 03-26-2013, 11:33:33 PM
Triple Jim Triple Jim is offline
Default Re: 1944 continental motors 300watt 12vdc navy generator
Sorry I don't know anything about it, but that is a really cool piece of equipment.
Old 01-26-2015, 08:58:02 PM
Brian Earp Brian Earp is offline
It is a second echelon battery charger 12V or 2 6V in series
Old 01-26-2015, 09:39:20 PM
Yup, battery charging would be my guess. @300 W it would push about 24 Amps into a 12v battery.
Guess it could also be used to drive radio equipment made to run on 12v.
Doc
Old 01-26-2015, 10:26:51 PM
I found of few of those online, and lots of info awhile ago.. got that one running and working about a year ago.. cool little gen.. for charging battery's in series or by themselves really quick.... some were for bombers to run the gun turrets and etc
Old 01-31-2015, 01:26:27 PM
plym49 plym49 is offline
That is a very nice find. Clean it up, get it running and it should be on a 4wd rig so that you always have 12v when wheeling.
Old 09-24-2018, 10:28:47 PM
drsteel drsteel is offline
I have one of these, would like some info on same. And, what is the value?
Old 09-25-2018, 05:44:44 PM
model EAG-1 gas engine and gen. 1/2 hp. 2500 rpm. s/n 22874, 1944 dept. of navy. gen. output is 12 dc. any info on this unit would be helpful, and, are parts available, such as piston rings.... thanks
Onan EAK-1 12VDC Generator, 1 HP, 400 Watt Manual? Merc300SD Onan Generators 6 05-08-2017 02:58:19 PM
Continental Motors AA7 need help raynebow Small Air Cooled Gasoline Engines 3 12-15-2011 07:54:43 PM
Continental Motors Engine questions tinkerman73 Antique Gas Engine Discussion 2 08-14-2011 09:50:19 PM
continental motors Dan WW Antique Gas Engine Discussion 5 07-24-2006 09:42:51 AM
Tiny Tim 12VDC Generator Tom Jamboretz Generators & Electric Motors General Discussion 1 05-16-2004 11:48:56 PM
