Iron Horse Canadian Military 30 Volt Generator PU-5008/U
this thread has 5 replies and has been viewed 5228 times
Old 05-08-2013, 10:11:08 PM
Kammer0072000 Kammer0072000 is offline
Photo Iron Horse Canadian Military 30 Volt Generator PU-5008/U
Iron Horse PU-5008/U
Canadian Military Generator
30 volt 300 watt
Serial # 601220
Picked this up in the fall. Really happy with it as it turned out well.
The Following 6 Users Say Thank You to Kammer0072000 For This Post:
Old 05-08-2013, 10:14:29 PM
Default Re: Iron Horse Canadian Military 30 Volt Generator PU-5008/U
The Following User Says Thank You to Kammer0072000 For This Post:
Old 05-08-2013, 10:21:51 PM
The Following 2 Users Say Thank You to Kammer0072000 For This Post:
Old 05-10-2013, 06:21:11 PM
Bigjoedo Bigjoedo is offline
Images: 21
Excellent Restoration, would love to see a video of it running.
Bigjoedo
Old 07-03-2013, 12:12:24 AM
Just a little video I put together to show her off a bit. This a military verson of the rugged little CH1 genset made by Johnson Motors (OMC) in Peterborough Ontario. 30 volt @ 10 amps which makes it good for 300 watts. I believe they use to bolt these to the fenders of jeeps to keep the batteries on the field radios of the day charged up. Kinda neet is the generator can be used to start the engine as showned in the video. Odd is the fact is was painted olive drab gloss??? It received the full treatment including new rings, valve job complete teardown and rebuild.
In the video you can see the adjustable current output from 0 to about 10 amps charging 2 12 volt car batteries hooked in series.
Old 12-26-2013, 05:15:23 PM
m606paz m606paz is offline
Hi
I need make a Guard reproduction .
Any drawing some with measurements?
Thanks in advance!
Do I need a 6 or 12 volt? 1943 GENERATOR MILITARY M5 johnnyrock70 Military MEP and Aircraft Gen-Sets 10 12-17-2012 09:54:42 PM
Iron Horse generator, stuck valves and no power, DreyeIce Generators & Electric Motors General Discussion 8 12-30-2011 08:00:04 PM
1945 cummins A 1 military 32 volt HELP californicate Vintage Diesel and Oil Engines 7 12-26-2011 03:10:16 AM
Iron Horse Generator Junkologist Small Air Cooled Gasoline Engines 9 12-30-2010 01:55:34 PM
Interesting---12 Volt Lights off 24 Volt Generator MEP=016b SDHomesteader Military MEP and Aircraft Gen-Sets 10 10-16-2009 08:56:53 PM
