Military Standard 4A032 ignition woes
this thread has 24 replies and has been viewed 6499 times
Old 11-04-2018, 05:22:29 AM
Rich Mc Rich Mc is offline
Default Re: 4A032 ignition woes
Do you have the breaker or breakerless ignition?
Old 11-09-2018, 05:39:41 AM
AlaskaStar AlaskaStar is offline
Breaker less ignition.
If I switch it off before it is warmed up, it shuts down like it is supposed to.
Thus, the switch is not defective.
Old 11-09-2018, 05:21:43 PM
If you don't have the engine wiring diagram here is a link. I suspect something is not right in the terminal box behind the starting pulley. The switch should kill the engine at all times. Check all your connections and terminals.
http://rattrig.com/Documents%20&%20M...805-262-14.pdf see page 5-59
Old 11-12-2018, 05:30:28 PM
Turns out I have a weak magnets in the coil box up front, and weak spark gives the same symptoms as too much fuel, and it would rapidly foul the cylinders, making it run on compression ignition (firing on the glowing carbon deposit).
Where can I get a new magnet?
My thoughts are to make a new one from neodymium (I have a machine shop so I can make something to put two barrel magnets in that will fit exactly in the same shape and housing) but time dictate that I buy one for now...
Old 11-12-2018, 06:17:38 PM
Try here
Saturn is closing forever on 12/31/18
It probably be best to give them a call
http://www.saturnsurplus.com/
Teledyne 4A032 military engine Landser Multi-Cylinder Stationary Engines and Power Units 2 06-28-2015 03:48:22 PM
Wisconsin TRA12D ignition woes s100 Wisconsin Engines 7 02-01-2015 09:16:04 AM
Briggs 23D Ignition Woes gootsch Small Air Cooled Gasoline Engines 5 09-22-2014 01:28:00 PM
Military 4A032-4 Engine notmuch Small Air Cooled Gasoline Engines 9 07-03-2010 12:39:38 AM
Military 3kw 4A032 Engine Question.. FredRoary Generators & Electric Motors General Discussion 4 08-05-2005 01:28:07 PM
