Onan Manuals Repository
this thread has 39 replies and has been viewed 9958 times
Old 07-24-2018, 04:40:47 PM
RichRigert RichRigert is offline
Default Re: Onan Manuals Repository
Help please. I looked but could not find my wiring diagram.
I have an Onan 15kw single phase diesel generator. Can't get to turn over on run or auto. Hoping somebody knows wiring diagram for it. Thanks Rich
15.ordjc-3cr/1337ab
serial A790385402
Old 07-24-2018, 06:01:57 PM
Your build sheet and wiring diagrams should be attached.
If you need help, please start a thread and include the complete model & ser. numbers as you did here.
The Following 5 Users Say Thank You to Max Thompson For This Post:
  #33
Old 01-01-2019, 12:11:41 PM
rcossette52 rcossette52 is offline
Thank you for the manuals. I just purchased a vintage 35ED powered by a Ford Y block. The voltage is 575 so manuals don't quite cover that part. Possible a special build?
Originally Posted by rcossette52 View Post
Onan Model 35ED 9R8/765 S/N 107B574030
How do I determine if wired Delta or Wye?
Old 01-01-2019, 01:21:56 PM
MBB MBB is offline
Here is some information on your unit.
The Following 3 Users Say Thank You to MBB For This Post:
  #35
Old 01-01-2019, 10:02:05 PM
MBB MBB is offline
rcossette52 Post your own thread and you will get some more information. This thread is about posting manuals. Thanks
Old 01-01-2019, 10:38:49 PM
KPack KPack is offline
Try this 926-0003 ED operator manual
https://www.dropbox.com/s/74zkp7kdl6...810ED.pdf?dl=0
Old 01-08-2019, 06:49:31 PM
dapoags dapoags is offline
New to the site, We recently received a Onan Generator( w/o any manual) and I've been assigned the job getting it running and servicing. It appears to have been out of service for some time, perhaps not started for 10+ years. see specs below:
From your website it appears the engine is a 1970 CSG 639 (3.9L), I would be very greatfull have if someone could help me with questions
Is there a separate manual or do I use the CSG 649 manual?
How do I refer to the Engine when purchasing parts (eg. Ford F150)?
Are there unique parts?
I would appreciate any advice on getting it up and running again, I plan to flush all the coolant and change oil, plugs, cap, rotor, cables, etc., but want to purchase the correct parts.
Onan
Electric Plant
Model and Spec. No.
30.0EK-15R/9238C
SN: 0670205039
STDBY. KW 30 KVA 37.5
CONT. 25 KVA 31.25
PH 3
PF .3
CY. 60 RPM 1800
Ford Industrial Power Products
Serial is 39982 A-1-HM
Engine Displ 240
Model C5PF -6005-A SO31
The Following User Says Thank You to dapoags For This Post:
  #38
Old 01-08-2019, 07:32:20 PM
If you will start a thread with 30 EK in the title and your info below in the body of the thread, you will get all the info you can use (and maybe a little more).
Welcome to The Stak.
30.0EK-15R/9238C
SN: 0670205039
CONT. 25 KVA 31.25
PH 3
PF .3
CY. 60 RPM 1800
Engine Displ 240
The Following 2 Users Say Thank You to Max Thompson For This Post:
  #39
Old 02-08-2019, 02:27:42 PM
GeneratorJeff GeneratorJeff is offline
Hi guys I'm hunting for a manual online for speed to work on this today if possible but will order one and wait unless someone knows how to scare up a digital copy the service manual for an Onan 90 DYC. Catalog part number for manual is 900-0150. The index referenced on this thread does in fact have the parts and operators manual but not the service manual.
I found the owners manual here already but my tech says he needs the service manual. But just showing you what type it is: http://www.skilledcrafting.com/onanf...20(5-1977).pdf
I've got something funky with it over revving at start up, self killing, then it engages the starter automatically and like 3-4 seconds prematurely before the engine has coasted to a stop. I also know that when my driver working as my proxy tested it before loading it with the seller they had to flash but flashing it was of no effect when we monkeyed with it the other day.
I can post a video elsewhere if someone reading this could diagnose or I will order the service manual if it's not lurking on the web.
Old 02-08-2019, 07:34:10 PM
Zeromedic Zeromedic is offline
Hi Jeff,
The 900-0150 manual covers many of the Onan UR gensets, including the DYC
You will find it near the top of any of the archives. Take a look: http://www.skilledcrafting.com/onanfiles/
Since the engine is made by Allis Chalmers not Onan or Cummins you may have to look elsewhere
for an engine service manual. The Onan manual will cover wiring, controls, generator parts.
You can start a new thread with DYC in the subject line if you would like more help.
Steve
on edit: if your AC engine is a 3500 MK II you will also find that manual in the OEM subfolder above.
Onan 12.5 JC manuals Deneh Onan Generators 11 04-03-2017 01:08:41 AM
onan MJC 10.0 manuals please Chas183 Onan Generators 15 09-21-2016 04:18:43 PM
Onan Manuals stretch67 Onan Generators 1 11-11-2012 10:53:32 PM
Onan 2LK-1R manuals lestr Onan Generators 4 01-31-2012 03:13:22 AM
Onan manuals DRP and DRN Applejack Generators & Electric Motors General Discussion 3 09-17-2008 09:52:03 PM
