MEP 003A Blew its Ammeter Circuit
this thread has 30 replies and has been viewed 1215 times
Old 08-05-2018, 08:58:48 PM
reybo reybo is offline
Default Re: MEP 003A Blew its Ammeter Circuit
Originally Posted by Radiomike View Post
... Moving Iron meters will respond to DC as well as AC so it is easy to check the movement with a D cell and a swamp resistor.
Mike
Mike,
Swamp resistor? New term to me. All the google search tells me about swamp resistors involves transistors. What don't I know?
Old 08-06-2018, 02:12:35 AM
Power Power is offline
I think you are in the wrong place. You should go to https://www.steelsoldiers.com. There is an entire section on MEP units. Some participants are experts. For a start, visit Thread: MEP-003A problems. Post and members will tell you what happened,and where to get replacement part.
Old 08-06-2018, 09:28:12 AM
I went to steel soldiers before I came here, and found myself trapped in the Vehicle forum and could not escape. I'll have another try.
Old 08-06-2018, 10:35:23 AM
dependable dependable is offline
Originally Posted by reybo View Post
Are they equally suspect in causing this? The circumstance -- turning on the AC kicked the overload switch --certainly suggests a part got overloaded, not some other demon like mouse-gnawed wiring.
I was thinking arc of an overload could break a loose connection, and I've found loose connections on the units I own.
On Steelsoldiers forum, go to Auxillary equipment section, as noted above, there is a lot of info, free TMs, and helpful people who work on these all the time.
Old 08-06-2018, 10:47:55 AM
Good points. Found my way around at steel soldiers this morning and carried this thread there. 4 and 5 years ago they helped me choose an 003 and set it up.
Old 08-06-2018, 11:55:16 AM
Vanman Vanman is offline
When you get to the root of the problem, don't forget to report back here so we aren't left hanging!
Old 08-06-2018, 01:08:34 PM
Will do. Part of my approach on the net. I've annually updated some of my Amazon reviews as much as 5 times.
Old 08-06-2018, 07:01:25 PM
Radiomike Radiomike is offline
Have you managed to measure the resistance (continuity) of the meter and CT. The meter should be a very low resistance, only a few ohms, as will be the CT. If the CT or meter is open circuit then be very cautious about running the generator again.
If the ammeter is 1A full scale deflection and is a moving iron type then a 1.5V DC battery with a 1ohm series resistor (swamp) should give you some deflection on the meter. The resistor will limit the current to avoid damaging the meter. If you have another meter that reads to 1A then you can compare the calibrations.
Depending on the construction of the CT, bar or wound primary, these can be simply qualitatively tested with an AC source.
Mike
Old 08-06-2018, 11:17:30 PM
Depending on the construction of the CT, bar or wound primary, these can be simply qualitatively tested with an AC source. Mike
In the last decade, I sold every piece of test equipment I own on ebay, except a large Variac.
Old 11-19-2018, 05:19:16 PM
ronciecka ronciecka is offline
There are 3 CT transformers in this generator. Only one is used for single phase, the other two are for three phase. Check the resistance of all three and if one is different swap it with one of the others. If all CT transformers read the same then your ammeter is bad.
The Following User Says Thank You to ronciecka For This Post:
Look what the Wind blew in SDP Antique Gas Engine Discussion 21 07-05-2013 09:20:46 PM
Top shed tarp just blew off. Paul Spence Antique Gas Engine Discussion 11 12-12-2007 04:32:29 PM
An ill wind blew on the 15.ordjc 4xr/9172aa Joe Onan Generators 19 01-09-2007 12:08:19 AM
Onan/Cummins MEP 003A 10KS genset trips DC circuit breaker Mike Cales Onan Generators 4 11-20-2004 03:22:30 PM
MEP 003A DC circuit breaker trips when try to star Mike Cales Generators & Electric Motors General Discussion 0 09-09-2004 11:31:29 AM
