Sparta Economy ID
this thread has 11 replies and has been viewed 1644 times
Old 10-03-2017, 08:55:13 AM
kelden kelden is offline
Default Sparta Economy ID
I just bought I believe a horse and a half Sparta,not sure. Looks like my economy except the oiler is behind the water tank and has a one bar Webster mag. No tag on it,but complete otherwise. any help please.
Thanks, Kelden
Old 10-03-2017, 09:09:05 AM
Just bought this Economy with no tag,otherwise complete. Looks like my one and half econ except oiler is behind the water cooler and has a single bar Webster. Any advise will help.
Thanks. Kelden
Old 10-03-2017, 10:16:59 AM
Tom Cwach's Avatar
Tom Cwach Tom Cwach is offline
Default Re: sparta econ ID
Need picture. D series had no tag. Serial number on end of crankshaft. Open top water hopper.
Old 10-03-2017, 12:03:51 PM
Thanks. Kelden
Sounds like a model "E". A photo would confirm that. What model is your other Economy?
Old 10-03-2017, 03:56:57 PM
Kelden,
I'm not a Sparta expert but the Webster mags didn't come on the Economy's until after Hercules took over late in 1913-14. So that probably isn't a Sparta. Others can weigh in as I said I'm not an expert. You'll probably find you answer though otherwise looking through the Sparta threads.
Kevin
Old 10-04-2017, 07:56:28 AM
my other one is a model E, 1923 Rounded corners on water hopper and oiler tube thru
water hopper. This one has more sharp corners, also oiler behind hopper with a one bar Webster.
Thanks for any help.
---------- Post added at 07:56:28 AM ---------- Previous post was at 07:54:34 AM ----------
Thanks, I will check.
Old 10-04-2017, 08:18:18 AM
The earlier "E" engines are as you describe. I don't know exactly when the oiler tube was moved, but it was late in the "E" engine production. With a date of 1923, I am surprised your other engine isn't tagged as an "F".
Old 10-04-2017, 12:21:08 PM
Default Re: Sparta Economy ID
Take a close look at the ends of the crankshaft. On the early engines, the S/N was stamped into the crank. I has a 1913 Hercules, and it was as you described except that it has a single magnet Webster Tripolar on it. S/N started 51---
Old 10-04-2017, 09:03:11 PM
Dave Nielsen Dave Nielsen is offline
If it is a Sparta it will have the Lunkenheimer mixer on it. The 1hp, 1 1/2hp Sparta's, D's, and early E's had a elongated water hopper opening. Not the standard square opening as on the later Economy's. A picture would help. The early 1hp Sparta's had the governor in the cam gear and not the standard fly ball governor.
The Following 2 Users Say Thank You to Dave Nielsen For This Post:
Old 10-05-2017, 11:50:19 AM
Thanks, Kelden
If you go here:
http://www.herculesengines.com/hercules/econ_pics.html
and scroll down to the middle of the page, you will see several photos of a typical model "E" Economy. Further down the page is a model "F" engine which I am guessing looks like your "other engine". Near the top of the page are photos of Sparta and "D" engines. They are quite distinctive.
Old 10-05-2017, 12:50:30 PM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
Images: 27
Maybe your 1923 is a Hercules and not an Economy with rounded corners. Are you able to post pictures of both engines so we can help you out?
Joel
Old 10-09-2017, 08:17:29 AM
Mike Deacon Mike Deacon is offline
Here’s my Sparta 1hp. Does your look like this..hope it helps.. regards,Mike..
Sparta Economy Tim Rostar Antique Gas Engine Discussion 22 10-03-2017 07:57:37 PM
Sparta Economy ID kelden Antique Engine Photos 1 10-03-2017 03:56:57 PM
Sparta Economy CX 6HP Mrnick Antique Gas Engine Discussion 3 04-13-2017 12:47:34 PM
Sparta Economy HP D Davis Antique Gas Engine Discussion 10 10-24-2011 09:10:55 PM
1hp Sparta Economy Rich Hudak Antique Gas Engine Discussion 6 07-20-2011 11:56:49 AM
