1929 Allis Chalmers Kerosene 20 35
this thread has 66 replies and has been viewed 6494 times
Old 08-29-2017, 08:43:13 AM
Russ Hamm's Avatar
Images: 1
Default Re: 1929 Allis Chalmers Kerosene 20 35
22-36 IH is the same also, i think.
Old 08-30-2017, 04:43:40 PM
Cody,
Nice that you had access to big belt sander for your radiator tanks, I had to go radiator tank surfing on the blacktop behind an old Buick to get mine milled off.
I used a wix 51503 in my purolator canister on my 27 model E.
You can check out my allis resto thread for more info if needed. These are great tractors, good luck on your project!
Tony
Old 09-12-2017, 09:32:03 PM
Cody Isaak Cody Isaak is offline
Well the Allis did what it was supposed to and threshed like a champ this past weekend there was no lack of power! Running perfect on straight kerosene and not breaking the bank either- Kero is a 1.20 per liter here, gas is 1.07 so pretty close. I am getting 35 to 40 psi of oil pressure with the new style filter what are other people getting? I will post some pics later but here are some videos. The first one we had set up and threshed a load already but apparently the straw blew right to the food stand so had to relocate.
https://www.youtube.com/watch?v=RFW5nzzcR94
https://www.youtube.com/watch?v=cFVj37vDluA
https://www.youtube.com/watch?v=ywxS1BxY-_Y
The Following 4 Users Say Thank You to Cody Isaak For This Post:
  #64
Old 09-12-2017, 09:42:13 PM
My Grandpa jumped at the chance to look after it
Name:	2017-09-12 20.38.10.jpg
ID:	291026   Click image for larger version
Name:	2017-09-12 20.37.34.jpg
ID:	291027   Click image for larger version
Name:	2017-09-12 20.36.57.jpg
ID:	291028   Click image for larger version
Name:	2017-09-12 20.36.09.jpg
  #65
Old 09-12-2017, 09:44:31 PM
Last of the pics
Name:	2017-09-12 20.35.52.jpg
ID:	291030   Click image for larger version
Name:	2017-09-12 20.35.23.jpg
The Following User Says Thank You to Cody Isaak For This Post:
  #66
Old 09-13-2017, 11:21:59 AM
Phil Johnson's Avatar
Looks good Cody. Looks like you had a good day there. Nice radiator blind!! Do you have to change your carb setting much when switching over to Kero??
I had my '28 out at the Ukrainian village show last weekend to run their thresher, same as last year. Had a good day weather wise and a large crowd.
I think the 'ol Allis has developed a head gasket leak on the front head so it's going to have to come apart for the first time to deal with that. It ran OK but I noticed the occasional puff of white smoke and it didn't start as readily as usual when warm.
It'll be done in good time---impossible might take a little longer!
Old 09-13-2017, 07:31:50 PM
It's not much of an adjustment between the two and really I don't mess with it now that I got it set when we were threshing, if you notice in the videos I had it a bit rich then once we got going I started leaning it out. If I let the tractor run for more than 10 minns on gas it will start backfiring cause the exaust gets a big portion of the intake pretty hot
The Following 2 Users Say Thank You to Cody Isaak For This Post:
1925 and 1929 20-35 Allis Chalmers tractors Jacob WI Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 50 07-29-2017 11:54:23 PM
1929 Allis U Splashn Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 07-09-2016 10:04:44 PM
1929 Allis U Splashn Antique Farm Tractors 0 07-07-2016 09:46:32 PM
Wanted 1929 Allis Chalmers U Continental s10 Engine Parts pineknot Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 01-02-2014 03:30:20 AM
Odd 1929 Allis Chalmers 20-35 manifolds blktppr Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 01-12-2009 09:52:00 PM
