Another Fordson F
this thread has 47 replies and has been viewed 4878 times
Old 11-10-2015, 03:55:46 AM
audiobull's Avatar
audiobull audiobull is offline
Default Another Fordson F
Another F made it to the workshop yesterday
Condition unknown apart from good compression and engine turns. Will give it a service and try get her started. Going to keep the rat look on this one as the other will be my special one once it is complete.
Any ideas what I can do with the rear wheels to make them usable on the road. Obviously road bands but the cleats are going to be removed anyway because it seems to have 2 left feet so what other options are there?
ID:	238473   Click image for larger version
The Following 7 Users Say Thank You to audiobull For This Post:
Old 11-10-2015, 08:06:54 AM
Default Re: Another Fordson F
Audio,
Very nice Fordson - there used to be some of those in this area.
On a couple of tractors, I have made cleats out of flat rubber. On one, I was able to get rubber from a scrapper that had come from a large conveyor. Or you can possibly buy new - as thick as you can get it. It is easy to cut and shape and you simply bolt on. Counter sink the holes on road side. A friend here recently did a spoker JD similarly.
Back in the day, threshermen here actually used rubber like that when they started paving roads.
Best of luck with the Fordson,
Aloha,
RM
Old 11-10-2015, 09:16:19 AM
Steve Welker Steve Welker is offline
Looks like a 1925 or 26 from what I can see. Not a bad looking tractor. The 2 right hand wheels makes it look a little odd. With Fordsons you can't have just one! Only thing that sucks with taking off the cleats, is the tractor ends up sitting tail down. Finding thick rubber helps alot.
-Steve
The Following User Says Thank You to Steve Welker For This Post:
Old 11-11-2015, 02:56:24 PM
audiobull's Avatar
It is a 1925 Steve. An early one with a 456 serial so I have 2x 1925 F's
Had the wheels off and cleaned the bearings up but would seem the inner seal is dead and lets grease out but no big problem.
The rad leaks like a sieve so will need a new one. I have heard you could use an E27 radiator is this true?
I also have a core plug leaking water so not sure what to do about that or how I can replace them as I am sure they are copper?
Thank you G Willikers will fight getting the cleats off and then have a look around for some good thick rubber. I was thinking of vulcanised rubber such as on the traction engines but I expect that is a fair price.
ID:	238592   Click image for larger version
ID:	238593   Click image for larger version
ID:	238594   Click image for larger version
The Following 3 Users Say Thank You to audiobull For This Post:
Old 11-11-2015, 05:45:38 PM
FredB2 FredB2 is offline
my thinking is it would be work getting all those lugs off., and then tractor wouldn't look right, i'm thinking find some square washers, bolt one on each cleat , lay flat iron band on ground, roll tractor on band, weld flat iron band to washer, roll tractor and weld to each washer as you go, cut and butt weld band together to complete circle, don't have to remove cleats, keeps correct height, doesn't damage tractor, bolt rubber to band if wish. win, win, as they say.
Old 11-11-2015, 07:05:21 PM
Russ Hamm's Avatar
Images: 1
Does anybody know how some of these end up with two wheels like that? I have a parts unit that came that way, looked like it had been that way for a long time. Won't they kind of pull sideways under load like that?
Old 11-11-2015, 07:10:16 PM
Roy V Roy V is offline
Core plug[freeze plug/soft plug] should be soft steel.There are 2 types,cup style and flat[it will have a bit of a dome shape].I believe yours will be a flat type,measure outside diameter and should be available from any engine rebuilder or auto parts.The flat type is installed in hole against shoulder dome out then hit in center to expand.
The Following 2 Users Say Thank You to Roy V For This Post:
Old 11-11-2015, 11:14:51 PM
E27-N radiator core would be the same. In fact entire radiator would fit, but look odd.
Core plugs are 1 1/4" flat style. Below is a picture of the plug. Sealed Power part number is 381-1011. This was for a bag of 12. I purchased these at a local NAPA auto parts store. I replace these on every tractor, after a very intensive block flushing.
-Steve
The Following 2 Users Say Thank You to Steve Welker For This Post:
Old 11-13-2015, 12:23:18 AM
I know that if you can find a store with a good Dorman old school drawer organizer system, they used to be stocking part for the drawers. Used to work in a parts store that had the metal ones and we had them by the piece.
Old 11-13-2015, 03:56:53 AM
audiobull's Avatar
I had thought it was just the rush to get it made for sale from the person I brought it off but they said they had seen a few others like that.
I had maybe thought if the implement/plough was facing the opposite way it would pull the tractor so put the wheels the other way round and it should equal it out? It would only pull in soggy conditions with a weight on the back I would guess?
---------- Post added at 07:56 ---------- Previous post was at 07:50 ----------
Great thank you everyone. Great to hear it is a "standard" part.... got to be one of the only widely available parts for the F
Great on the rad also I will get a new and make some gaskets up for it.
In regards to the wheels I am still not sure which way to go. I will have to keep an eye out for a set of normal ones that are the correct way round and probably get the cleats cut off of this set with a torch as that seems to be the cleanest and easiest way of doing it.
My First Fordson Pete Mandt Antique Farm Tractors 14 10-17-2014 10:57:52 PM
Fordson F in USA, How much?? Herbert Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 03-06-2014 04:56:52 PM
Fordson F Value? Jeff Blaney Antique Farm Tractors 1 03-24-2008 08:21:39 PM
Fordson F Marcel P Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 14 05-14-2007 01:37:48 PM
FORDSON FRANK KELLOGG Antique Engine Archives 4 08-24-2001 02:25:48 AM
