New Member of the Twin City Twin Cam Fraternity
this thread has 22 replies and has been viewed 1794 times
Old 11-14-2016, 10:54:17 AM
J Ware J Ware is offline
Default New Member of the Twin City Twin Cam Fraternity
Hello everyone, this weekend I picked up the newest addition to my collection of TC tractors, a 17-28, there is no serial number tag but from what I can gather it falls in the 1928 era. The gentleman I got it from said it ran well until it developed mag issues, has a marvel schebler carb and is missing the air cleaner. All of this is minor. It also has new fenders. The trip was not to be forgotten for a while, 2 flats on the trailer on the way home made for a long day. I would like to thank Kent, it was nice meeting you and your wife Mona. Jim
ID:	268070   Click image for larger version
ID:	268071   Click image for larger version
ID:	268072   Click image for larger version
Old 11-14-2016, 11:00:30 AM
Russ Hamm's Avatar
Images: 1
Default Re: New member of the Twin City twin cam fraternity
Thats great, congrats.
Yours is sure further ahead than mine right now.
Old 11-14-2016, 11:30:06 AM
Phil Johnson's Avatar
Looks to be a pretty decent TC. Definitely a later model as it has the straight front axle with bearings in the wheels and the large fuel tank.
Old 11-14-2016, 12:07:21 PM
Nice, and it will never get much water in the engine in that position.
Old 11-14-2016, 04:55:30 PM
Molinegb Molinegb is offline
Is there motor serial number on rear mount?
The Following User Says Thank You to Molinegb For This Post:
Old 11-14-2016, 11:22:01 PM
Congratulations! It looks like your tractor has lots of potential!
As I reviewed the pictures I see that your tractor has two different rear wheels. It has an early "12-20" style rear wheel on the right side with a TW43A hub. The one on the left would be the correct one with the FT110A hub. Note that the FT rim was "double punched" to provide for more lug and grouser options on the later tractors.
The original carb was probably the universally frustrating Holley All-Fuel with the coil that extended into the exhaust manifold for preheating. The exhaust manifold appears to be sound which is good as usable ones are sometimes hard to find.
I'll be watching for updates. Good luck on your project!
The Following 2 Users Say Thank You to Mark Schneider For This Post:
Old 11-15-2016, 11:52:52 AM
Looks like you might need a left front wheel. I think I have a good spare, but it's a little far away for economical shipping. I'll check.
Old 11-16-2016, 03:30:19 PM
The engine number is 25576, would that make this tractor a 1928? Mark, I hadn't noticed the difference in the rear wheels, but just like the changed frame and bent front wheel, this is all character it gained from it's years of service to one or several owners.
After some more looking over, I see the govenor will need some attention, and I can follow Marks instructional posts as a guide for a quality rebuild. I'm going to age the fenders and fan shroud next year? I've crossed the biggest hurdle, I got my tractor, now to finish what needs to be done to make it run and operate correctly. Jim
Old 11-16-2016, 10:28:09 PM
Roy V Roy V is offline
Looks great.I want one!
Old 11-17-2016, 11:54:15 AM
I would say it's a '28. I have a '28 - serial #25506 engine#24075. Slightly earlier than yours, Jim.
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 115 04-03-2018 09:26:40 PM
Twin City Big Twin Cam up for Sale Mark Schneider Live Auctions of Engines, Tractors and Old Iron 27 03-19-2017 10:58:08 PM
Twin City rhawke Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 24 11-15-2015 01:14:51 AM
Twin City Help Ben Zimmerer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 02-04-2012 07:39:27 PM
Two more Twin City's Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 21 08-17-2010 04:28:27 PM
