1929 Allis Chalmers Kerosene 20 35
this thread has 66 replies and has been viewed 6912 times
Old 12-28-2016, 10:11:04 PM
Cody Isaak Cody Isaak is offline
Default Re: 1929 Allis Chalmers Kerosene 20 35
Been working on the Allis and decided to do radiator first so took the top tank off and discovered a mouse hotel but unfortunately it gets worse. When taking the lower tank off 3 corners were cracked previously and broke off so I guess I'm in the market for a lower tank . But I suppose I could mayby cut pieces of steel to fit and braze them on?
Name:	2016-12-28 20.06.05.jpg
ID:	271270   Click image for larger version
Name:	2016-12-28 20.06.31.jpg
The Following 5 Users Say Thank You to Cody Isaak For This Post:
Old 12-28-2016, 10:45:08 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Their all broken on those flanges, we just made up some pieces and brazed them on. Trick is to preheat the whole casting.
Old 12-29-2016, 01:06:40 AM
Keep your ears to the ground and maybe you can find a lower for your tractor. Otherwise, brazing some good cast back on is the best bet I suppose.
Old 12-29-2016, 09:06:40 AM
Russ Hamm's Avatar
Images: 1
I have sure had to weld a lot of those over the years, i actually mig weld such with preheat like mentioned above. Works pretty good, haven't had any problems.
Old 12-29-2016, 12:53:30 PM
Phil Johnson's Avatar
I've got 3 spare rads, Cody. I'll check and see if I have a good bottom tank. I'll put it with the seat pedestal if I do.
Old 12-31-2016, 12:03:37 AM
Hi Cody. Checked the rads today and I have a few good bottom tanks.
Old 12-31-2016, 12:24:53 AM
Thanx phil the problem is I'm not sure when I'm going to make it your way, I think I'm gunna have a go at fixing this one if I can
Old 12-31-2016, 10:01:22 AM
Molinegb Molinegb is offline
Know of two 20-35's three piles west of my yard. One is running and one parts. Another 2 in Killarney area. Not sure where dealer was.
Old 01-06-2017, 10:39:33 PM
Anyone know were to get the right roller bearings for the fan?
Old 01-06-2017, 10:45:57 PM
Cody,
Do you have numbers off the bearings? Measurements?
1925 and 1929 20-35 Allis Chalmers tractors Jacob WI Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 50 07-29-2017 11:54:23 PM
1929 Allis U Splashn Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 07-09-2016 10:04:44 PM
1929 Allis U Splashn Antique Farm Tractors 0 07-07-2016 09:46:32 PM
Wanted 1929 Allis Chalmers U Continental s10 Engine Parts pineknot Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 01-02-2014 03:30:20 AM
Odd 1929 Allis Chalmers 20-35 manifolds blktppr Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 01-12-2009 09:52:00 PM
