1929 Allis Chalmers Kerosene 20 35
this thread has 66 replies and has been viewed 6829 times
Old 01-06-2017, 10:47:54 PM
Cody Isaak Cody Isaak is offline
Default Re: 1929 Allis Chalmers Kerosene 20 35
Not yet I haven't pulled it apart yet just thought I'd ask in case anyone knew
Old 01-07-2017, 12:45:58 PM
Phil Johnson's Avatar
Phil Johnson Phil Johnson is online now
Cody, my original parts manual lists them as Timken Bearing C7523. That must be a number for a complete cup/cone assembly. You're probably best to see if there are any numbers showing on the bearings themselves.
I've never had to replace any of these on mine. If they're a little loose, they can be adjusted by removing the fan blades and adjusting the nut on the end of the spindle, much like a front wheel bearing. The felt seal in the back of the rear bearing usually is shot and the front gasket between the fan and the hub dries out and then the oil drains or is thrown out of the reservoir around the bearings. Some grease these instead of using oil.
The Following 2 Users Say Thank You to Phil Johnson For This Post:
  #33
Old 01-17-2017, 08:40:37 PM
Well the Allis threw a curveball. I started to take the water manifold off and both studs broke off inside the head and as you can see the second one took a chunk with it!!!!!!!. I'm assuming the one head will have to find a replacement but can the other one be fixed?
Name:	2017-01-17 18.36.27.jpg
ID:	272656   Click image for larger version
Name:	2017-01-17 18.35.33.jpg
ID:	272657   Click image for larger version
Name:	2017-01-17 18.34.42.jpg
ID:	272658   Click image for larger version
Name:	2017-01-17 18.35.06.jpg
The Following 3 Users Say Thank You to Cody Isaak For This Post:
  #34
Old 01-17-2017, 10:07:56 PM
Those studs thread into a boss cast in the head but are usually threaded right through the head. When you remove the heads you can probably drill the remains out and clean up the threads. On the one that broke a piece out, you'll have to see how much broke out when you get the head off. It may be repairable. If not, I may still have an extra head or two laying around.
  #35
Old 01-17-2017, 11:43:24 PM
Jacob WI Jacob WI is offline
That stinks Cody! It's never fun to find something broken, or worse yet when you break it yourself
But we've all been there, and that is how we learn.
I've seen on one of the 20-35 threads here (Tony I believe?) where they fixed a head with a bad threaded section on the water manifold stud area by welding in a nut to the head to replace the broken out area. You may be able to to that with your broken head.
The first step is to get the head off and access what is all broken.
The one with the twisted off stud should be no big deal to fix, like Phil said drill it out and run a tap through to clean up the treads.
While we are talking water manifolds, I have a question. Looking through the parts book I see it calls for "Fibre Washer 1/2" I.D." E-157. To seal the brass nut to the water manifold. What puzzles me is it calls for 3 of these.
Why? Shouldn't there only be 2? Typo, Or am I missing something
Putting my '27 back together and this is one thing I don't think I have heard or read yet.
Thanks, and good luck! keep us posted what you find
Edit: Well, it must be a typo I think. I looked in one of my other manuals and it only calls for two in that one. Interesting note, back then they cost .05 each.
Old 01-18-2017, 06:11:15 PM
Jim Mickelson Jim Mickelson is offline
What is the serial# of your 20-35? & thank you for sharing I also have a 29 20-35
Old 04-02-2017, 10:08:29 PM
Hi Cody,
Wondering how things are going with your '29, did you get the heads off to see what things look like? I've been crossing my fingers for you.
I also wanted to pick your brain on how the tractor is set up being it is a Kerosene tractor. I'd like to learn more about this.
From the small starting tank on the left fender, does the gas line go down to the sediment bowl in the bottom of the fuel tank? So there is still only one line to the carb, correct?
Is the Kingston carb the same regardless of what fuel the tractor is set up for, just adjust the needle valve accordingly?
I suppose you haven't had a chance to play with actually running the tractor on kerosene yet, but do you plan on trying it?
For those that have, what do you use? Kerosene, Diesel, Jet Fuel, or a mixture, etc...?
Or is running kerosene a thing of the past, and everyone just runs them on gas? Seems finding a place that sells kerosene is tricky at best these days.
Old 04-29-2017, 09:10:07 PM
hey I haven't really had time to do much more to it but I hope too soon in a couple weeks maybe. I assume that the gas line went to the sediment bowl originally since there is only one fuel inlet in the carb. But all the lines and the sediment bowl were gone so I put a bowl and three way valve from a john deere so that I could run kerosene and I do plan to when I get the tractor up on its legs again. I have had good luck with Jet fuel or winter diesel as kerosene in Rumelys and everyone else that ive talked to says the same.
The Following User Says Thank You to Cody Isaak For This Post:
  #39
Old 05-02-2017, 05:26:54 PM
TRS66 TRS66 is offline
I once owned a Kerosene 25-40 with the small starting gas tank on the left fender. The gas line went to the sediment bowl. There was a shut off valve at the bottom of the little gas tank. There was also a valve on the sediment bowl that opened and closed the big kerosene tank. I never used the big tank for fuel or ran it on kerosene so I don't absolutely know for certain how the whole thing worked, but as I recall there was an inlet line on the sediment bowl for the gas and an outlet line from the sediment bowl for either fuel to the carb. The sediment bowl threaded into the large kero tank. I think how it worked was that at start up the kero tank valve on the sediment bowl was turned off and the valve under the gas tank was opened. When the engine was sufficiently warmed up the kero tank valve was opened and the gas tank valve was closed, there would be a little blending until the gas was used up. To shut down I would think you would close the sediment bowl off and starve the tractor of kero so that at start up there would be purer gasoline. The 25-40 had a magneto off/on switch too, so I might be wrong on the shut off thing. That's how I think it went but like I said I am not 100% certain. The short answer is the kero model had a special sediment bowl designed for the switching of the different fuels.
The Following User Says Thank You to TRS66 For This Post:
  #40
Old 05-02-2017, 06:05:53 PM
Russ Hamm's Avatar
Images: 1
That is just like a McCormick- Deering.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
1925 and 1929 20-35 Allis Chalmers tractors Jacob WI Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 50 07-29-2017 11:54:23 PM
1929 Allis U Splashn Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 07-09-2016 10:04:44 PM
1929 Allis U Splashn Antique Farm Tractors 0 07-07-2016 09:46:32 PM
Wanted 1929 Allis Chalmers U Continental s10 Engine Parts pineknot Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 01-02-2014 03:30:20 AM
Odd 1929 Allis Chalmers 20-35 manifolds blktppr Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 01-12-2009 09:52:00 PM
